85 Carrera 3.2 Targa
Which stud?
Hello everybody, great site here and proud to be a part of it! I have to replace one of the studs that hold the lower valve cover. I looked over and over through the catalog and I am just not seeing which one is the one I need. Thanks
No man with a good car needs to be justified. |
Part # 999-062-010-02-M260 It is an M8-35 stud
It isn't anything fancy. You could buy a rod of M8 allthread and cut a suitable length off too.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
AutoBahned
easies thing is just go to a fastener house and buy one!
Year-and-a-half old thread, I know, but it seems a good place for these questions:
There's no magic, must-have metal for these low-torque valve cover studs is there? I can just match them up at a local retailer, right? Nuts are solidly stuck on two of three studs that backed out when I pulled one of the lower covers.
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...." -- William Faulkner |
AutoBahned
sure, I would use steel however...
Home of the Whopper
[QUOTE=NOLAsc;5387158]Year-and-a-half old thread, I know, but it seems a good place for these questions:
There's no magic, must-have metal for these low-torque valve cover studs is there? I can just match them up at a local retailer, right? Nuts are solidly stuck on two of three studs that backed out when I pulled one of the lower covers.[/QUOTE Did you try to double nut the other end? I have never had a problem getting off a stuck nut this way. Clean threads with wire wheel.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Yep. Tried double nutting and soaking with pb blaster. They are really stuck. I will try again, but am going to pick up some new ones just in case.
