One more 993 Conversion is road ready -Thank God
After a long jorney and frustration the SC--> 993 Conversion is road ready .Here are some ready pics
loose nut behind wheel
Let's get some updates people!
Mine is back at the painter getting the nose, tail, and rear bumper fitted and painted.
80 911sc/993 GT-2 body/3.6L motor 71 VW Convert (300 hp 2332 FI turbo) 97 Passat TDI 320K miles and counting |
bump for more updates people!
Gentlemen.
Super interesting thread. Nice builds. How did U guys solve the front bumper bar Question? Did it end up with the bar delete,? Did anyone go for the 993 aluminum or the911 aluminum bumper bar? H |
yeah lets get some updates, need inspiration
I'm currently in the middle of a 3.6 conversion. Mine has the bumper bars deleted.
grateful user
Sash I like the color!! whats the story on the rear lamps, will used ones go rite in or is there a kit? are they hard to source? Would like to upgrade.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
don gilbert you have a 964 body not a 993, Kevin
grateful user
no, kevin, I have a 75 targa with 993 "style" front fenders with oem 993 headlights, c2 skirts and bumpers. i would like the 993 taillights to match. thanks for letting me know what i built K.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. Last edited by don gilbert; 05-24-2010 at 07:15 PM.. |
sorry mr gilbert if i offended you but the front fenders you have look like 993 fenders but are not unless you put spacers on whiches raises the front of the hood, also a 964 style front bumper will not work on a 993, on the rear you still have sc type tail lights, the rear quarters and openings for the tail lights are different between the 993 and sc/964 tail light openings. unless you cut the opening out the best you can do is 964 tail lights, my sc with 964 stuff, Kevin
grateful user
No offense taken, and i am not Mr Gilbert, its Don, or dude or whatever, I have 993"""style""" fenders, and I want 993 taillamps to match my 993 headlamps, why wont they work? I see them on every other conversion, what has to be done to make em work, thats is the question i asked in the first post. the yellow car with the rs wing at the top of the page has them, and its an SC, so i know it can be done.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. Last edited by don gilbert; 05-24-2010 at 07:58 PM.. |
look at the corners they are round, i believe the width is way wider too. i just think itll be a major rework to get them to fit, the whole rear fender and tail light shape is different, you will be suprised at the change up to c2
Kevin, Love the color! do you have pics or links to you 3.6 conversion? I'm in the middle of gathering everything I saw a bunch of posts when you did yours.
grateful user
I dont like the c2 lamps. I just searched and found a dozen or so sc, carreras, and other early cars with 993 taillamps. How much hacking is involved Kevin.
don i know the rear fenders are different and the rear deck is different, i couldnt find any sc with 993 tail lights i do admit i like the 993 tail lights,
cudabnu yea speed yellow great color, i put this car together several years ago and it sits, has 07 plates 200 miles since built. might sell http://forums.pelicanparts.com/porsche-911-technical-forum/100145-3-6-conversion-motor-part-5-2-a.htmlit, any questions and i can help, Kevin |
Somewhere in the Midwest
Unless you are a good metal or glass guy, forget about 993 rear lights without new quarter panels, bumper and center reflector panel.
All the SC's or anything earlier than '95 that you found on your search have been fitted with the right parts to accept the lights. They have been properly updated. I've never seen an earlier car with just the tail lights of a 993 and no others related updating. It'd look kinda strange IMO. Quote:
But the 993 conversion will be a semi daily driver.
got the 3.6 conversion installed, should have it up and running this weekend, then I can finish the body
Simone conversion! Before and after...although were not done
![]() Before - ![]() After -
The car looks great, what rear deck and wing did you use?
1978 race car scca GT2 1998 C2S sold 1996 C4S sold 1973 911 T restored with 2.7 RS running gear 1970 911 E Project |
