Dial91177s's Avatar
Send a message via Skype™ to Dial91177s
Targa bar/cover re-paint...
Good morning, I'm in the midst of trying to remove the Targa bar cover from my '89 911 so that I can have it repainted........previous owner tried to "sand" off all of the factory black and it's not all the pretty.
I've been successful in removing the old rubber/weatherstripping seal that runs around the front part of the band (911 565 091 47) and have already ordered a replacement for later. They issue comes when I goto remove the inner lining as I understand there are (2) nuts at the base of both sides that needed to be removed before the cover will come off.
Is there anyone that's done this or perhaps a tech thread out there that can help guide me through.........??
Brian
Old 12-12-2009, 04:39 AM
grateful user
don gilbert's Avatar
Brian, its pretty easy, pull back all the w/stripping and find all the little screws, and the 4 nuts under the wheel well (2 on each side that will prob. break off)
i decided to paint mine to,and now i am glad i did.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 12-12-2009, 05:58 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Ahhhh!!!
Metal or black only - no paint!
Well, it's your car - do whatever you want. My $0.02 though.
Black Cars Matter
Old 12-12-2009, 06:08 AM
grateful user
On a soft top targa, black is prob. a better choice, I was fortunate to find a 75 with the factory hard top (one of 47 produced) and went a little custom,
Old 12-12-2009, 06:19 AM
Wow, that actually does look fantastic with the hardtop - didn't see that before. Very nice/rare find and beautiful overall. Love the color, too!
Black Cars Matter
Old 12-12-2009, 06:36 AM
Dial91177s's Avatar
Dan/Phile.......thanks for the quick response.......after another 30min of searchingi finally found them......of course, removal of the Carbon Canister in the RR wheel well should be fun so that I can actually get to the nuts down below. Little dissapointed in the PET Catalog as I search high and low but couldn't find the location of those 2 nuts !
Oh, in terms of paint or not.......was actually thinking of having it actually chrome dipped or painted with a new chrome product I've seen at the race shop.....PO has a number of "swirl" marks on it that I'd like to remove, but not sure I like the stainless look against my Linen Metallic factory paint........perhaps Black is the right choice afterall
Old 12-12-2009, 06:38 AM
If your going black, have it powdercoated.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-12-2009, 06:40 AM
Virginia Rocks!
VaSteve's Avatar
Search a thread started by "ianc". Good info in there.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 12-12-2009, 06:45 AM
Transplanted User
mkossler's Avatar
Don,
That top and bar really came out something special! Not to hijack the thread, but do you have any more photos, maybe a profile shot?
Cheers,
Matty K. - 82 SC Targa - SCWDP member #0052
"Racing - the sport that requires more than one ball to participate"
Old 12-12-2009, 11:28 AM
i used wurth matt black. looks good
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 12-12-2009, 11:56 AM
grateful user
sure Matty, thanks, always ready to show off
Old 12-13-2009, 05:30 AM
chocolatelab's Avatar
The trim on my car is the silver/chrome. So I went from the body color hoop to the stainless.
IMOthe best looks are as follows
black trim-black hoop
silver/chrome trim-stainless hoop
custom color trim- custom color hoop
Also, I picked up my stainless hoop for 100 dollars from a dismanter. I did that because I wasnt convinced until it went on that stainless was the way to go.
** small piece of advice **
use lots of blue tape and towels when you take the hoop off and put it on.
once you get the screws out and wiggle the hoop out it will sort of spring out and could cause some paint damage
BEFORE
AFTER
1978 911sc Targa Sold 2001 996 Cab Sold
2006 Cayenne S Silver Wifes Car for sale
2011 Jeep Wrangler Silver for sale
2010 Toyota Prius Black for sale
2016 BMW 328D wagon
Old 12-13-2009, 06:58 AM
Stainless bar looks great. Is the front destroyed during the removal process or is there a away to save it? Also, is the rear seal/gasket an over the counter item? Thanks.
'84 Carrera
3.4 twin plug
Old 12-13-2009, 10:32 AM
GothingNC's Avatar
Stainless looks great with the Mocha Brown
I was thinking about the same for mine but then I would need to strip the window molding and vent window frames.
Here is a good thread about removing the Targa bar
http://forums.pelicanparts.com/porsche-911-technical-forum/201576-removing-targa-bar.html
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 12-13-2009, 10:49 AM
you can remove the front and rear seals without destroying them.
my rear one was in terrible condition and havent sucked it up and bought a new one.
the seal that goes against the targa top comes off with a little gentle work and is easily reglued back into place
2016 BMW 328D wagon
Old 12-13-2009, 01:54 PM
WUNDERWAFFE
JINKATIN's Avatar
I re-painted mine without taking it off, if I was able to do it; anyone can do it. I sanded it, applied primer X2 coats, and 3 coats of Santin Black. Hope this helps
Charlie
1986 Carrera
Old 04-10-2010, 09:11 AM
amarillo73's Avatar
Targa bar...
Here is my powder-coated targa bar and trim done 13 years ago, still looks great! Good Luck!
1973 911T Targa 2.7 RS specs.
1969 912 Targa (sold)
1985 Jeep CJ7 (sold)
2002 Silverado Crew 2500HD 8.1L
2003 28 ft. Trail Bay 5th wheel
2006 Saturn Vue V6 (wife's) faster than you might think.
Old 04-10-2010, 08:39 PM
KCinBR's Avatar
I did the powder coat 3 years ago in a satin finish, still looks great......now lets see if I can find a pic.[IMG]
From Targa top rebuild
[/IMG]
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 04-11-2010, 02:11 PM
Tags
cover , removal , targa
