Dumb G50 shift coupler question
I am pulling the 3.2 and G50 from an 88 and I can't get the shift coupler off the tranny. I took the 2 bolts off that attach it to the shift rod that goes to the shifter and what I guess is an alignment bolt but I can't get it loose from the tranny.
Before I take a hammer and punch to it am I missing anything? It isn't threaded or anything is it?
Plenty of experience with 915 shift couplers but first time with a G50
Thanks in advance
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 03-14-2019, 05:36 PM
There is a single horizontal bolt on the trans shifter which is very close to the trans cover.
Come in from the drivers side on the horizontal. Swivel 13 on long extension gets you on once you have cleared the rubber seal
Very unique bolt.
Don’t break the aluminum inside shifter, it’s expensive
The G 50 trans can be lowered in the front to change the starter unlike the 915
Bruce
Old 03-14-2019, 06:07 PM
Very unique bolt.
Bruce
I have that one out, it is a 13 mm bolt right? I also have the two off of the shift coupler that goes to the shift rod. It looks a tad rusty. Guess I need some rust buster and a little persuasion.
Tom Feeney
1970 911 T
1973 911 T
Old 03-14-2019, 06:16 PM
Diss Member
Quicksilver's Avatar
You don't have to touch the shift coupler or anything inside the car. The single bolt is under the car right where the shifter shaft comes out of the transmission. The bolt has a stepped shaft to hook the linkage shaft to the transmission with no slop. If I remember correctly it has a 10mm head. (maybe as large as 12mm)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-14-2019, 07:49 PM
I was preparing for a partial drop yesterday - part of this was separating the shift coupler from the nose of the G50.
1) From inside the car, remove the shift coupler cover.
2) Don't undo anything on the shift coupler but unhitch the rubber boot and push it back through the tunnel towards the back of the car.
3) Put the gearbox in 2nd or 4th gear.
4) Underneath the car continue pulling back the rubber boot until you can get to the single bolt holding the shift coupler and G50 selector shaft together.
5) With a 13mm spanner undo and remove the single bolt through the coupler and the G50 selector rod.
6) Use a small pry bar (or similar) to separate the coupler from the G50 selector rod - you want to move the coupler to the front of the car whilst not pulling the G50 out of 2nd/4th gear.
Can be a little frustrating. Last time I was in there I fitted a new rubber boot and that made it a bit of a pain this time.
Once separated there isn't a huge amount of gap between the coupler and the G50 - but it's enough
"Racing is Life. Anything that happens before, or after, is just waiting"
1988 Carrera 3.2 Sport Coupe - my mistress
2012 BMW F11 touring - the dog bus!
2017 VW T6 Transporter - the holiday bus/workhorse
Old 03-14-2019, 11:37 PM
Great info, thanks everyone
Tom Feeney
1970 911 T
1973 911 T
Old 03-15-2019, 04:38 AM
