Horn options
I replaced the twin horns with that small euro air horn that Griot's Garage sells. Worked really well easy install where originals were.
But after two years its just a low buzz. I think it could not take all the road grime. Anyone out there have an idea on some loud air horns that are durable and can take the beating, or maybe a different location to put them? Thank you Barclay _____________ 1981SC coupe |
Try FIAMM puck-style horns....available at FLAPS....and point them DOWN, ( not forward). Or any puck style but don't point them facing front.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Agreed. I also have the WOLO horn installed and the instructions indicate the opening must be angled downward so as not to ingest water or road-grime.
Horns
I too had to replace the original horns. Before purchasing, I had an opportunity to hear how new stock horns sounded and was not impressed. I was impressed however with the price of the new stock horns.
I removed the old horn set. I used the existing bracket as-is (no mods whatsoever) and bolted in aftermarket horns. Twice (or more) the sound at half (or much less) the price. I highly recommend it.
83 911 Production Cab #10
... was that a typo, Which after market one did you on?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
French Import
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
New Old Stock
By "new stock" I mean NOS (new old stock). I seem to remember it costing a few hundred. I can't imagine the aftermarkets cost me much at all (it's been a few years).
Don't remember what brand I purchased. You can use pretty much any 12 vdc unit. You basically just bolt it onto the car's bracket. Of course you will have to bear the burden of knowing that, under your car, resides a non-Porsche part. |
I bought a pair of new 996 horns for about $80. Same hi/lo harmonics as the SC horns, sound pleasant and polite on a quick tap - get penetrating pretty fast. Fraction of the weight of the trumpets.
Made up an small 4-wire adapter harness for the fancy new weatherproof terminals to adapt to the spades on the factory harness, bolted them in around the wheel in about 15 minutes. Pointed them down and forward so they're out of any spray from the wheel. It's been 3 years/20,000 miles now and they still work great - yes, I drive in the rain. You could put pretty much anything on - even Ford or GM horns - but why would you want to do that?
'77 S with '78 930 power and a few other things. |
Formerly known as Syzygy
Are the euro horns any different than the ones for North America of that vintage (80's)?
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Thanks for the responses, I'm going to look into the Fiamm horn
Funny story
The reason I decided to replace the original anemic horns was that I was driving in a parking lot one day in my 911 and saw two parked cars across from each other both start backing up at the same time. Neither appeared to see the other. I immediately started honking the horn. It was actually kinda embarrassing. I think I've heard louder horns on bicycles.
Sadly neither car heard my little pissy horns and they ended up backing into each other. I decided then that, for the good of all mankind, I needed to replace the horns.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
+ 1 with Trojwl ! Only I have not replaced mine. Any suggestions for a better sounding horn?
Mike '84 911 Carrera Coupe (totaled) '83 911 SC Coupe ‘06 Aston Martin Vantage V8 |
Suggestions
I would imagine Autpzone, Pep Boys, etc. probably have them on shelf. On line try Ebay or J.C.Whitney.
Any that you find should be easily adaptable. |
Come on, you know you want a train horn:
YouTube - train horn Last edited by schaklos; 08-30-2010 at 05:44 AM.. Reason: Fixed link |
Found The Fiamm Horn at Pep Boys, went for the high tone.
I was wondering if you can splice into the horn wires and install two of them, one high tone and one low tone or is that overkill? or will two be to much electrical draw? |
I believe most do come in pairs anyway. I think a pair of horns sound much better than a single unit.
Don't worry about amperage draw. |
Train horns are so "last year"...
