5String
Pulled a Stud
Looks like the racket I heard Monday was the result of a pulled stud on cylinder #6. Fearing that the clatter I heard was a spun rod bearing, I had the car hauled to TRE in Van Nuys, here in So Cal on Tuesday. Looks like they'll finally get around to starting on it Monday. Bitterly disappointed by the time lag. But not as disappointed as I am with a broken motor and an expensive repair bill. Guess we might as well do rings and valves while we're in there. Should at least solve a couple of nagging little oil leaks. Any low-cost (heh, funny idea, that) upgrades I ought to consider while we're in there?
And one more thing: Should it come to that, should repair costs get completely out hand, what's the best later engine to transplant into this '82 SC? I'd be grateful for any thoughts on this.
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files Last edited by 5String43; 09-17-2010 at 05:17 PM.. |
RETIRED
964 Cams?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
5String
Keep in mind that I have to be able to pass California emissions. I suspect a cam change would render that impossible. Worth looking at, though. Thanks for the suggestion.
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files |
I am with you on the "disappointed about the expensive repair" but that's the other side of Porsche ownership.
This is a good read for those who are thinking about buying an older Porsche. P-Cars are very dependable but when something does break, the repairs are hardly ever, inexpensive. Like someone on the board said "they are all 20k cars" Good luck on the repair, hope all goes well.
*2005 Markleeville "Death Ride" 5 Pass Finisher. 129 miles & 15,000 ft. of climbing *California Triple Crown Member (3 Double Centuries in 1 Year) *2003 Giant Carbon Fiber Road bike with Topolino Wheels + a lot of goodies *2000 Torelli road bike - Campagnolo Chorus equiped + a few goodies *1999 Litespeed titanium, full-suspension mountain bike Shimano XT equiped + a lot of goodies. Bill Carcot 1979 911SC - Sold (Searching for a Boxster) 2000 BMW Z3 |
I assume that you don't have a pulled stud - with an 82 SC, I would think you have a broken exhaust stud. If it were mine, from what I've read on here, I wouldn't replace the rings - I'd just do all the exhaust studs and a valve job. Button it up and enjoy.
If you have pass emissions in Calif, there's not much you can do to it - like exhaust work.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Did leak oil? I remebered pull head stud would mean oil leaks?
1983 911 SC |
5String
No oil leaks, at least none that I noticed. The guy at the shop told me that the stud was pulled, definately not broken. Re P-cars being $20,000 vehicles, I'm going to be well beyond this by the time this is over. Not good.
yea they are 20k cars, but maybe you just fix the stud? instead ofdoing the rest? My motor has done more miles than yours. I dont think i'll revamp the engine yet. But i am buying a 3.2 for spares.
1983 911 SC |
RETIRED
Mine passed with a little tweak of the mixture.....
How can you be "bitterly disappointed" by a shop that takes less than a week to start on a semi-involved project?
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Now in 993 land ...
George |
Now in 993 land ...
One more comment - the studs don't pull on the aluminum case 3.0. They usually break / snap.
Before you are too disappointed in the shop, remember that good people will always be busy. You can also go to the guy around the corner who has nobodies car in there. ![]() George |
This is why working on your old Porsche is mandatory for ownership. This is when you start learning the process. If there is only one stud to repair, it can be done with a repairt kit (that was very polular with the mag case studs). I would say, $1,000 when all is said and done and if you don't do the while in there stuff?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Curious.... is it typical for an SC stud break to be any one of the bottom 12 Dilivar, as a rule....when a broken SC stud is found? Or can it be just as common for it to be any one of the top-row steel ?
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Most stud failures, from what I understand and have experienced, are the lower dilivar studs. The material used in them is not well suited for the intended use. (This is a subject of great debate.)
I have found that one of the best parts of owning a 911 is working on it myself. It is great satisfaction to pull the motor (easy) and do a top end or complete rebuild. These motors are not hard to work on. There are a few special tools required, but nothing that will break the bank. These are air cooled motors with individual cylinders and heads and a common cam shaft; just like motorcycles of old. If you rebuild it to stock there is no guessing at tuning or whether or not a combination will work, making the repairs even easier. A broken stud will take you a couple of weekends in the garage. If it were mine I'd re-ring it, have the exhaust guides replaced and get a valve grind. Other than new studs, that would be it, unless something shows up during the tear-down. This web site is your single most valuable tool. Lindy ![]()
RETIRED
I've never seen a steel stud on an SC break......just those crappy Divilars.
When mine went on my 914/6 conversion, it sounded like playing cards in a bicycle spokes kinda noise.
5String
It's no big deal, I probably expressed this a bit too strongly - but my disappointment about the lag in time it will take to get my car back stems from a miscommunication. This car is my driver, so I need for it to be repaired as quickly as possible. Apparently a voice-mail message they left for me didn't make the trip, hence two days of work time lost. I guess that happens sometimes. Ah, well, it's all solved, and soon repairs will be under way.
And yes, the guys at the shop definately told me that a stud in cylinder #6 had pulled, not broken. At least when they did a check on the oil and filter, that all came out clean as a whistle. Looks like no bottom-end work is required.
Jack
Good luck Jack
85 Carrera Cab |
5String
Either very brave or incredibly stupid, I'm not sure which it is. But the car is in great shape - good interior, new brakes and tires, trans rebuilt 10k miles ago - hey, what could go wrong? Besides, I'm kind of semiretired, so don't plan to put all that much pressure on the car, so once I get this engine problem sorted out I should be good to go (here he crosses his fingers and toes).
