Most BMWs bikes run cats....
Originally Posted by paulgtr View Post
motorbikes don't run cats, and maybe they run solid lifters so they need the same oil additives that our early cars do?
unless removed by owners for wt reduction/flow.....
Old 04-28-2011, 08:02 AM
masterdave's Avatar
Thanks for all the advice guys. I dont know what the car currently runs I'll ask the previous owner what he used to put in it. I have worked on porsche's before, my first car in high school was a 924s that was given to me not running, and it was either make it work, or walk to school. So i feel confident under the hood. I also dident realize the car took 10quarts
Thanks for every thing
dave
Old 05-02-2011, 01:28 PM
Mo money = mo parts
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 05-02-2011, 02:19 PM
Somebody put the pin back in the grenade!
Dave have fun with the new car. You like the rest of us on this journey started with the simplest questions first. You will find out even the simple gets worked over here. Its because we dig the cars. Good Luck and find a mechanic that others trust so you can too.
Old 05-02-2011, 03:01 PM
RETIRED
Joe Bob's Avatar
20/50 Valvoline VR1 Racing oil.....
2012 ML350 3.0 Turbo Diesel
Old 05-02-2011, 03:10 PM
In a Turbo I'd only use a synthetic due to the heat and the turbine coking problems with normal oils. I've used Mobil 1 20-50 for over 30 years in 2 turbos and 4 or 5 normally aspirated and have never had a problem.And that is in Texas heat. I think they've recently switched formulations to the extended service 15-50. Discontinuing the normal 20-50 precisely because of the additional additives for our older engines.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-02-2011, 03:16 PM
Gerry van's Avatar
l use mobil 1 5w-50 and it actually says on the packaging "porsche approved"..
Old 05-02-2011, 03:56 PM
RETIRED
Joe Bob's Avatar
I wouldn't trust a Mobil product to wipe my ass with.
Old 05-02-2011, 03:58 PM
Gerry van's Avatar
Tell me more, bad experience yourself or heard bad stories..
Old 05-02-2011, 04:23 PM
Wash. State
nesslar's Avatar
Not my post originally, but......
Originally Posted by db_cooper View Post
I will add this to the thread that will not die. Below is a cut and paste from bobistheoilguy.com.
It looks like the John Deere Tractor oil (plus 50) has a big add package, 1700+ zinc and 1400+ phosphorus plus some moly for good measure. This fellow runs it in a boat. The oil looks very suitable for our air cooled engines. A plus would be, we can get this oil at any John Deere store.
Any thoughts?
i know we usually go over automotive uoa's here, but i wanted to throw this one into the mix, to show why i use john deere plus 50 motor oil.
the engine is a john deere marine 6076 (466) with 9798 hrs. engine is either run at wot or idle (lots of idle time, probably 30-40%) i have samples dating back to '92 on this particular engine, i'm only going to post most recent.
sample has 254 hrs., i generally run this oil to 350 hrs., but boat is layed-up until mid-april and i always put her to bed with fresh fluids
oil; john deere plus 50 15w-40
oilscan; through deere
sample date; 12/5/09
make-up oil; 10 qts (due to extensive ideling, hasn't changed since new)
iron................28
chromium............ 1
nickel.............. 1
aluminum............ 2
lead................ 1
copper.............. 1
tin.................<1
silver.............<.1
titanium............<1
silicon............. 4
boron..............133
sodium.............. 5
potassium..........<10
moly...............139
phosphorous.......1410
zinc..............1723
calcium...........4102
barium.............<10
magnesium...........15
antimony...........<30
vanadium............<1
fuel %vol...........<1
t/s %vol...........0.5
water %vol.........<.1
vis cs 100`c....... 15
oilscan doesn't offer tbn/tan to my knowledge, but this engine has always returned stellar uoa's
Old 05-02-2011, 04:30 PM
HarryD's Avatar
It probably does.
Now the real question is .... for which Porsches? After all, since 1998, Porsche did not build any flat tappet air cooled cars. And an oil ok for water cooled rooler tappet cars is not necessairily good for our cars.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-02-2011, 08:39 PM
HarryD's Avatar
For me it is lack of transparency.
At a fundemental level Mobil 1 is a good motor oil since is is formulated with a good bse stock (Type IV). It is the games with the additive package they played that has me not trusting them going forward.
Even today, they do not disclose the necessary quantitative data in their Product Data Sheets to help me know if I am getting what I want.
Mobil lost my trust when they changed formulations early in the transition from SL to SM oils but did not document the change nor notify the end users. In fact they insisted all was ok yet shortly therafter made some more changes to address the outcry.
Other oil manufacturers were more forthright with their data.
That is enough for me, but as I am fond of saying: your car, your money, your choice.
Harry
2020 MB E350 4Matic
Old 05-02-2011, 08:45 PM
aadrew10's Avatar
With the money I've saved using Castrol GTX, I can pay for a sweet rebuild when my engine blows up!
- Andrew
81SC
Old 05-02-2011, 08:51 PM
kramer747's Avatar
Originally Posted by gregwils View Post
lol
Old 05-02-2011, 09:03 PM
kramer747's Avatar
Guess what??? All the manufacturer's say their oil is the best. Hmmmmm
Old 05-02-2011, 09:05 PM
Gerry van's Avatar
So since l have some quantity of this oil (mobil 1) whst's the answer additives?
Old 05-03-2011, 12:33 AM
kramer747's Avatar
I would go ahead and just use it and then switch to the Castrol
Old 05-03-2011, 05:48 AM
Born to Lose, Live to Win
ramonesfreak's Avatar
i used synthetic only...10W30. im in upstate NY. no oil leaks. but every engine is different considering how it has been treated and where it has lived etc...
when i got my car, i simply continued putting in what the PO was putting in per my service receipts that came with the car
Old 05-03-2011, 05:58 AM
Mobil1 1 15w50 is getting harder to find reasonable priced.. walmart no longer carries it and neither does target... which leaves you to the dreaded "part stores".... I just paid $110 for m1 on an oil change....
I sat down and did a little meditation and it occurred to me that even for $150 Id spend the money on something that has never failed me, racing, or in any other car that I "tracked" etc... When I did my valves on my P car I inspected the cam lobes.. notta.. nothing.. smooth as a babies butt.
Mobil has an explanation of why reduced zinc with phosphates added will not cause flat tappet wear.. you can choose to believe them or not... but, please.. please do NOT try and wipe your ass with M1.. I agree with Joe Bob. This is not the intended use of the product and Mobil discourages use of M1 for anything other than its intended use.
Brad Penn on the other hand is capable of ANYTHING.. you may wipe your ass with it, you are fully covered by the Brad Penn warranty and prayers will be said on your behalf when the Brad Penn cult has its annual meeting.
JP
'76 911s Ice Green Metallic bone stock
Old 05-03-2011, 06:21 AM
Hey Romonesfreak... no issues with oil pressure on a 90F day? Id really like to run M1 high mileage but I've been afraid to do it... and you can't get it in anything more than I think 30wt.
JP
Old 05-03-2011, 06:23 AM
