notmytarga's Avatar
Snapping Noise Fixed - Door Stay - The Video
Hope everyone had a Happy Christmas - here is my gift to the collective!
Several door stay threads have complaints about noisy door stay movement. Mine was akin to a gunshot!
The fix shown below as far as I read was first promulgated by SW and confirmed by JW but is sort of lost in time and amoungst other door stay / limiter issues. I used a bolt on mine and shot a YouTube to demonstrate sound, movement, fitment and relief. It is a riviting 30 seconds!
I used a 6M 20mm hex cap head bolt and a nylock nut. Enough thread was exposed to allow the use of a 16 mm bolt by my estimation.
Did/does anyone have it worse than this (before it is fixed )?
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 12-26-2011, 08:34 AM
Mine sounded about like yours. A really loud popping sound on each dedent when opening the door. I made the same fix as you and no more popping. I have not seen anyone replace the factory pin. Are they not available?
Hugh Lindberg
1972 911
1970 Alfa Romeo 1300 GT Junior
Old 12-26-2011, 08:59 AM
Any one know if this a long term fix. I looks like the hole may be elongated and the clamp pressure is keeping it from popping. How long will this do the trick?
Thanks for posting the video.
Cheers Richard
Old 12-26-2011, 09:22 AM
too many projects 1983 sc
56 nomad's Avatar
post delete
Old 12-26-2011, 10:01 AM
Always learning
FYI Madre sells the correct hardware that looks a lot better than a bolt. Cheers
Old 12-28-2011, 03:30 PM
Taking it apart is easy
Jerome74911S's Avatar
How do you get the original roll pin out - or is it original? I tried a drift, various pliers, etc. No luck. It's awkward to get at the thing as it sits there.
I did a search and found a couple recommendations, but they haven't worked for me.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 01-01-2012, 12:52 PM
I used a longish drift and put a cloth shield against the sill metal where the hammer would strike. It took a surprising amount of force.
Old 01-01-2012, 03:58 PM
The above list a pin for the door hinge. The pin in question in this thread is the one in the door stay, where it connects to the small bracket on the door.
I don't object to using the bolt solution that others list above, I just find it difficult to remove the old pin without risking damage.
Jerome
Old 01-02-2012, 07:54 AM
Tags
door stay , noise , porsche 911
