Snapping Noise Fixed - Door Stay - The Video
Hope everyone had a Happy Christmas - here is my gift to the collective!
Several door stay threads have complaints about noisy door stay movement. Mine was akin to a gunshot! The fix shown below as far as I read was first promulgated by SW and confirmed by JW but is sort of lost in time and amoungst other door stay / limiter issues. I used a bolt on mine and shot a YouTube to demonstrate sound, movement, fitment and relief. It is a riviting 30 seconds! I used a 6M 20mm hex cap head bolt and a nylock nut. Enough thread was exposed to allow the use of a 16 mm bolt by my estimation. Did/does anyone have it worse than this (before it is fixed )?
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
Mine sounded about like yours. A really loud popping sound on each dedent when opening the door. I made the same fix as you and no more popping. I have not seen anyone replace the factory pin. Are they not available?
Hugh Lindberg 1972 911 1970 Alfa Romeo 1300 GT Junior |
Any one know if this a long term fix. I looks like the hole may be elongated and the clamp pressure is keeping it from popping. How long will this do the trick?
Thanks for posting the video. Cheers Richard |
too many projects 1983 sc
post delete
Always learning
FYI Madre sells the correct hardware that looks a lot better than a bolt. Cheers
Taking it apart is easy
How do you get the original roll pin out - or is it original? I tried a drift, various pliers, etc. No luck. It's awkward to get at the thing as it sits there.
I did a search and found a couple recommendations, but they haven't worked for me.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com Last edited by Jerome74911S; 01-01-2012 at 01:16 PM.. |
I used a longish drift and put a cloth shield against the sill metal where the hammer would strike. It took a surprising amount of force.
AutoBahned
??? http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911E§ion=INTpnl&page=3&bookmark=11&part_number=901-531-305-20-OEM |
I don't object to using the bolt solution that others list above, I just find it difficult to remove the old pin without risking damage.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
| Tags |
| door stay , noise , porsche 911 |
