Clutch pedal question
My car is an 88. Every now and then the clutch pedal will not come all the way back on release. I checked everything and there are no leaks or anything. The pedal cluster is in good shape, but there is no return spring on the clutch pedal. I do not even see any place to mount one.
I have looked in the manuals and see there is a pedal return spring, but what I don't know is was there one on the year I have? I don't even see where there could have been the pin to attach one end to on the bracket. Any info is greatly appreciated. TIA
Every cloud has a silver lining (except for the mushroom shaped ones, which have a lining of Iridium and Strontium 90) 08 Cayman, 88 911 Targa, 93 MR2 Turbo, 2012 Jeep JK |
1984 911 Targa - "Sabine"
Mine is an '84 and I believe by design they are the generally the same, but do have some variances due to the hydraulic clutch on the G50 transmission. Enclosed are a couple of pictures of my pedal cluster (84) when I took it apart to refurb it about a year ago. I'm not sure if the return spring you refer to is the one in the middle of the cluster however.
![]() ![]() ![]() And these are off the 86-89 clutch pedal cluster - hope it helps. ![]() ![]() Skip |
Thanks for the photos and illustration. I think the spring goes between the 2 points shown, but I could be wrong.
![]() I wonder if the later models had one at all.
Looking at the diagram / pictures in black and white, I can't see the pins that would allow the spring to connect. I do remember the challenge of adding that large spring to the points you identified, but don't see it on 87-89 version (it's a hydraulic clutch vice cable, so I wonder if #1 (clutch master cylinder rod) should act in lieu to provide the back pressure. Similarly to a brake master cylinder, if there is an internal diaphragm problem, the brake pedal doesn't return quickly either. Just a thought.
Skip |
Member 911 Anonymous
Your clutch pedal set up is completely different for pre-87. You have an adjustable eccentric bolt.
Remove the floor board and you can access the bolt using a long Allen socket.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
By any chance, does the clutch stick more often when its cold? I had the exact symptom, and it turned out that I had a small leak from the clutch slave cylinder.
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Spiderman
No spring ? My 87 is returned via the very large spring with about 3 or 5 coils shown above thats wound around the white plastic rod. Spring #4 on bushing #3. Does your car have those parts or is it like fbeatty's photos.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
You need to replace the clutch master and slave cylinders.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Thanks for the replies guys.
Jesse16 the photo was not mine, but one I lifted from Skip1 and marked with the line. megarian, warm or cold no real difference on the sticking. It only occurs every now and then with no regularity whatsoever DRACO as always good info, thank you. RSTarga thank you as well, I will mark replacements as my next project.
When I had those symptoms recently with my 88 I replaced the master cylinder and all was well. Note there were no leaks, just the non-returning pedal. I figured the slave was ok as it is only ~5 yo. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
