-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Cheap long hood...Another back date project (http://forums.pelicanparts.com/showthread.php?t=716480)
Rob 930 06-17-2016 02:28 PM
Subscribed. Wow, Chris great job. Look forward to seeing it one of these days.
Rob
cnielsen 06-17-2016 02:39 PM
Originally Posted by kenikh (Post 9158677)
16s. 245 RE11 in the rear. Chris you went with 8s and 9s right?
Sent from my Nexus 6P using Tapatalk
I had 851 8's on the front but it was a little too much tire for the fender. I swapped for 7x16 with 205 on the front and 9x16 with 245 on the rear.
Fixer 06-17-2016 04:26 PM
Now this is one sweet ride, hadn't seen this thread.
Who did you use for the anodizing? and great prep work on the wheels.
I bet it's a handful in the rain [in a good way] with all that HP/torque.
Good luck with it, great job!
cnielsen 06-18-2016 10:45 PM
Wheels were done by Art Brass in Seattle and the anodizing done by Electrofinishing in Kent, WA.
It's fine in the rain as far as power goes. The way the motor is set up, it is incredibly docile during normal driving. However, squezing the throttle even just a little bit is when it starts to get scary. In the rain, you have to drive with a light foot ;)
cnielsen 07-03-2016 03:02 PM
A couple shots after the vintage races today
http://forums.pelicanparts.com/uploa...1467583244.jpg
http://forums.pelicanparts.com/uploa...1467583350.jpg
RRWood 07-03-2016 03:48 PM
The color combo is just incredible.
0-60Motorsports 11-17-2016 12:38 AM
Another awesome build. love the color combo and seat design.
SunnyWay 11-20-2016 02:14 PM
Singer cool. Nice build !
kenikh 11-20-2016 02:17 PM
No Singer can keep up with this car.
Gib Bosworth 11-20-2016 02:24 PM
Really great job, Chris...another winner!
mjshira 11-20-2016 06:18 PM
I thought I had a sleeper,,, wow!
cnielsen 11-20-2016 07:33 PM
Thanks everyone!
Looking forward to getting it back from my friends fabrication shop! He has had it for quite a while. Items on the to-do list...
1. Front splitter / skid plate / oil cooler ducting
2. Oil line going directly from the turbo to the sump pump. This being a 965 motor, there is a drain plug on the side of the case. I'm hoping we can utilize that to bypass both scavenge pump we previously installed.
3. Muffler façade to cover all the turbo stuff and look like an old style 911 banana muffler.
Outlaw_singer 11-21-2016 01:37 AM
I've bee following this one for quite a while now. What a thing of beauty!
JoshCole1122 11-21-2016 08:06 AM
Pure Sex!
quattrorunner 11-21-2016 12:22 PM
Just probably my favorite car!
Just creamy
Trackrash 11-21-2016 01:00 PM
Definitely a build for the ages. Awesome in every way. Love everything about it.
Easy Tiger 11-21-2016 01:34 PM
Great Backdate!
I went the cheaper fiberglass direction, but if I did it again I would get metal front fenders. The bumpers are so much lighter though...
http://forums.pelicanparts.com/uploa...1479763850.jpg
http://forums.pelicanparts.com/uploa...1479763867.jpg
http://forums.pelicanparts.com/uploa...1479764039.jpg
http://forums.pelicanparts.com/uploa...1479764056.jpg
cnielsen 11-21-2016 06:07 PM
Nice hot rod Easy Tiger!
I wanted to keep everything all metal if possible. Not for any other reason than I know how to weld, but I don't know how to work with fiberglass.
I may end up needing to modify my front bumper for more air flow to the oil coolers. We'll see how the under belly ducting helps to lower the temps.
cnielsen 01-30-2017 08:27 PM
A few recent upgrades...
In an attempt to eliminate the two scavenge pumps we were using on the car, we had a custom oil line fabricated that goes directly from the turbo and into the sump of the engine. The sump pump is more powerful than any scavenge pump and the gravity feed line will keep the oil out of the turbo....hopefully 😉
http://forums.pelicanparts.com/uploa...1485836777.JPG
cnielsen 01-30-2017 08:37 PM
The next project was to fabricate a custom muffler faćade. The turbo parts hanging below the rear bumper detract from the esthetics of the backdated bodywork. I believe that the banana muffler is a vital part of the early 911 body lines. The turbo and all the plumbing consume all the space that would usually house the banana muffler so we designed a muffler faćade. The purpose would be to hide all the turbo bits, give the illusion of a banana muffler and function as a heat shield for the body work.
http://forums.pelicanparts.com/uploa...1485837253.JPG
