-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Cheap long hood...Another back date project (http://forums.pelicanparts.com/showthread.php?t=716480)
cnielsen 01-30-2017 09:05 PM
Lastly, and most important modification...
Even with two oil coolers, oil temps were higher than my other normally aspirated cars. This engine makes a lot of power, and therefore, a lot of BTU's! The theory is that air was taking the path of least resistance and was going around/under the oil coolers and not through them. The solution was to enclose the bottom of the car so the air was forced to go though the oil coolers. As an added benefit, we would incorporate a skid plate and a air splitter to aid in downforce.
http://forums.pelicanparts.com/uploa...1485839027.JPG
kenikh 01-30-2017 09:06 PM
And there's the money shot...
cnielsen 01-30-2017 09:22 PM
http://forums.pelicanparts.com/uploa...1485839738.JPG
And last but not least....the leather covered center console!
http://forums.pelicanparts.com/uploa...1485840127.JPG
0-60Motorsports 01-30-2017 09:36 PM
Stunning Stunning Build.
al lkosmal 01-30-2017 10:34 PM
Chris...that is pretty f...ing crazy cool.,,,,and you will need all the down force you can get..
al
riverstonefly 01-30-2017 11:05 PM
So much talent my friend
Sent from my XT1650 using Tapatalk
Elombard 01-31-2017 03:24 AM
Did the bottom plate bring temps down?
What normally goes in the spot where you put the turbo oil drain?
Great fab work!
Willem Fick 01-31-2017 03:31 AM
After reading through, and thoroughly enjoying this thread (and I just love all your builds Chris!), I am just again amused by the use of the term "Cheap" in the thread title!
Definitely playing the lottery again this weekend!
onboost 01-31-2017 05:24 AM
That is a great piece of fab-work!! Pretty much the same theory there as Porsche moved to with 964/993 under panels etc.. but with the incorporated splitter & skid plate is just tits!
obscene 01-31-2017 05:53 AM
amazing.
cnielsen 01-31-2017 06:38 AM
Great fab work!
Thanks for the comments everyone!
I need to give credit where credit is due. My friend Josh Ewing at Ewing's Customs did all the fab work. This kind of fabrication (art work) is beyond my pay grade!.
I just got the car back yesterday so I haven't had he opportunity for a test drive yet. Weather permitting, hopefully I will get a chance in the next couple days. I would be happy with a 20 degree drop in temps :)
The turbo drain normally has a catch can and a suction feed line going up to the scavenge pump which is located in front of the driver side cam shaft. That pump wasn't sufficient to remove all the oil from the turbo so I was getting blow by into the exhaust. The theory there is that these pumps are really "push pumps" and not "pull pumps" so they don't do a great job of suctioning the line. An auxiliary electric pump cured this when we mounted it below the level of the turbo so it was a gravity feed. However, that added to the amount of equipment and plumbing under the motor. This drain tube will hopefully simplify things a lot and allow me to remove both scavenge pumps.
Fixer 01-31-2017 06:47 AM
Very cool Chris (pun I know) I wonder if the inlet is large enough? Curious to read what you find.
DaveE 01-31-2017 09:02 AM
I'm backdating a '76. This is a HUGE help! Thanks [emoji4]
Jonny042 01-31-2017 02:13 PM
Wow. Nice! Those scoops look a little TOO nice, were they borrowed from another car? If not, do you know how he formed them?
Great build. Love the sleeper look.
cnielsen 01-31-2017 02:51 PM
That is what Josh does for a living so I guarantee those scoops are 100% hand formed for only this application. Needless to say, he takes pride in his work!
kenikh 01-31-2017 02:51 PM
Josh is indeed the man
Sent from my Nexus 6P using Tapatalk
jjeffries 01-31-2017 05:17 PM
That pan is spectacular work. Will it have a drain hole(s) in the fuel tank relief area (for rain water etc)? Someone will say "He won't drive it in the rain" but you do reside in a pretty wet part of the world. John in CT.
RSBob 01-31-2017 05:51 PM
Amazing, yes. An engineering feat? Yes! Another masterpiece in the making? Definitely YES. 'Cheap'? In an Orwellian sense, a downright bargain! ;).
The pan looks like it belongs on a fighter plane. It's a shame it's under the car. Can't wait to see it in flight mode, perhaps to Sonoma. Just don't melt the front of mine as you hit the afterburners.
1979-930 01-31-2017 08:38 PM
Wow Chris. I am in awe at how factory stamped those pieces look. Pure art and craftsmanship.
911 Rod 02-01-2017 06:31 AM
Yes, wow is all I can say.
