Timing chain gasket
Does engine need to be dropped on 1985 targa to replace gasket on cover for timing chain? Thanks in advance .and about how many hours involved if it needs to be dropped?
1985 Targa 3.2 Black on black,16"Fuch,23 years California car. Last edited by tanmanbgoh; 01-09-2013 at 09:11 AM.. |
Certainly you won't have to drop the engine. All chain tensioner work can be done simply by removing the muffler (and some assorted tinware). Just replacing the gasket should be easy, maybe a couple of hours at most to get everything off, replace the gasket, and put everything back together.
Might be a good idea to take a look at your chain ramps, sprockets, and tensioners (visual inspection, try to compress them by hand etc.) while you are in there.
Noah 79 SC minerva blue metallic Eureka CA / Boulder CO Physics is like sex, yes there are some practical applications, but that's not why we do it. |
That's best news I've heard since the cleveland Indians won in 1954....lol ps.has anyone actually change that gasket. I know the gasket is like 10dollars,so it's all labor..is couple hours actually possible? Thanks
1985 Targa 3.2 Black on black,16"Fuch,23 years California car. |
I've replaced mine as part of a tensioner upgrade. As stated, remove the muffler and tin for easy access. Removal of the covers is stright forward. You are supposed to replace all the nyloc nuts and washers as well. Just toss the old ones so you won't be tempted to reuse them. I think the torque should be about 7 foot pouns/84 inch pounds. Don't overtighten them.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross Last edited by tharbert; 01-09-2013 at 11:36 AM.. Reason: sp |
Tired Member
I'm about to do the same task (with engine out). Do the gaskets get any sealer or are they installed dry?
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Installed dry is fine, sealant used there is usually the sign of a good (bad) hack job.
I like to use the Curil-T sealant on gaskets like this - seems to seal better IMHO.
FWIW, on my '89 it was the gasket BEHIND the chain cover that was leaking at about the 200k mark. This is the round gasket between the chain housing box and the cam cover. Required removal of the cam sprockets and chain box to get to it, but was still managable with the engine installed. HTH, Chuck.H '89 TurboLookTarga, 344kmiles |
What about the spray copper gasket stuff? Any problems with using that? I think I have a leak in this area on my '88 which I rebuilt a couple of years ago.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
GAFB
I use Curil-T on these as well. Make absolutely sure the leak isn't actually:
-chain housing to case gasket -tensioner and/or cam oil lines -cam thrust plate o-ring and/or gasket If the muffler hasn't been off recently, you're going to need a new gasket(s) there, too. On these I use exhaust sealant. |
French Import
![]() Quote:
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
I've always found removing the muffler fairly straightforward, although my car was in California for most of its life (and its an SC, so only 3 bolts to remove). Nice thing about the muffler bolts is that if one is rusted you can just break it off, extract the pieces, and then replace it.
French Import
By the look of things the muffler bolts look like they have never been removed...
It gave me an excuse to buy an angle grinder on sale last week. ![]()
Oxyacetylene is the trick to muffler bolt removal. Takes about 1 minute / bolt. Especially handy for the cat, where you can't fit the angle grinder. SS bolts with bronze nuts comes apart nicely every time - I use 5/16 SAE, because it's easy to come by and 13mm wrenches fit.
It's helpful to disconnect the 2 rear motor mounts and drop the engine a couple of inches to get the rear sheetmetal piece out.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
French Import
You are not kidding about the cat bolt being out of reach...
If you jack the rear of your car way way up, you shouldn't lose any significant amount of oil.
