My first purchase was in ~84, a used '78 Targa with 37,000 miles, rubber clutch failed shortly thereafter. Then the chain tensioners. Maintenance by Squire and myself. Wife and I put another 60,000 miles on the Targa with never a thought that A/C would be nice to have. Drove to Memphis and back, HOT mid-west, Kansas, Nebraska, etc. Got up at 0-dark-thirty, drove with the top off until the sun and heat became unbearable. Breakfast, top on, drive to late evening. Mostly 90 MPH+.
~1995, Purchased a '79 Targa, 80k miles, SLC, gift to a friend, A/C with aftermarket belly condensor. Wife and I drive it from SLC to Nyssa, NE oregon with satisfactory A/C. He seems to be happy with it. ~ 1997, Purshased another 78 Targa, virtual duplicate of our own 78, gift to our son. Ripped out and tossed afternarket, dealer installed, A/C. ~ 1998, Purschased an (the) 88 Carrera for our company's lead software engineer. He went on to greater things, challenges, we kept the car. 2000, purschased a used 1999 C2....tinited the windows. Drove cross country to Daytona (24 hours race)and back. Mightily impressed with interior comfort, climate control, vs the Carrera. Later trip to/from Memphis (Blues Ball Auction)the front radiator fan failed in long construction zone across AR, HOT, August. Figured out how to keep the engine cooled and have functional A/C, comfortable all the way home where Squire repaired the fan controller. That all got me to thinking about the shortcoming of the A/C in our 88 Carrera...so I started experimenting and shortly discovered the major problem. Not enough condensor cooling airflow in certain situations. Added the initial set of rear engine lid cooling fans...BIG improvement. Installed a factory A/C system ("pull-a-part") in our 78 Targa and did the same thing to it, except the additional cooling fans had to be mounted under the rear lid spoiler. Also a BIG, improvement. |
Oh, but it most certainly does. Look at the relative ease of north/south, front to back, cooling airflow through the fins/vanes of the factory front condensor vs either of the aftermarket one's. The aftermarket condensors might very well outperform the factory one when the blower/ fan is the primary source of cooling airflow, but not, NEVER, underway. |
That's actually MY argument.....the aftermarket front condensors are designed such that they mostly BLOCK front to back roadway airflow.
Brando
What is your motivation is what I'm asking sincerely. Thanks.
Turbo powa! 1977 911s. it's cool |
he is a socialist liberal democrat trying to save all of us stupid fools from ourselves and spending our hard earned money on snake oil. LOL.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Banned
He won't answer those, so it seems unlikely he won't give you any SUBSTANTIAL answers to your technical questions. He obviously thinks that GTI stuff is very overpriced. Considering the rest of the market, GTI seems to have a reasonable price going for the stuff. He also seems to think that somehow, if you could only move air over the condensers more, the system would be adequate - then uses his own experience as "proof". Well, my experience happens to be this: When I got the car, it had a stock system. It blew cool air, but in the summer, the temp. delta was only about 15 degrees from OAT. And that was cruising along at 65 MPH. I was not impressed. Giving it a full R12 charge only helped marginally when the OAT was 100+ degrees. Not only that, but after one year, I had to add five additional ounces of R12, and the subsequent dye leak check saw zero leaks at any of the fittings. So, search Pelican. Swap front condenser, evaporator evap fan, temp control and fan switches, go to barrier hose, switch to R134a, courtesy of GTI. Well, now I can get the cabin very cold, and it will stay cool even when the car sits at a light. It doesn't take that long to fully cool down the black interior, and on the highway, the car stays as cold as I want it to be only if the car sits at idle in the full sun does the air output warm noticably - but the air output is still cool enough to keep up with the heat input. The curious thing about wwest's posts is that he holds up his personal experience as definitive, but everyone else's experiences don't matter in the least. Never mind being terrible science, his position is not even remotely logical. Where did my R12 go? If it had leaked at a fitting or a hole or even some relief valve, the dye would show up under UV. There is only ONE correct answer for where the R12 went, because logic dictates only one potential place, when you've eliminated the metal parts and the fittings. Yet I am to believe that system overpressure is the cause of my R12 leak, and that somehow, only the gas leaked, and none of the oil with dye in it. That's tough to explain away. In fact, wwest doesn't even bother - he'll just change the subject. He makes claims about condenser flow, without ever having tested the flows. Without even having the things in his hands. He just looks at a picture and *knows*. Yes, his intellectual forebearers *knew* that the world was flat, too. Then, after that, they *knew* that the Earth was the center of the universe. It's not a matter of what wwest knows. It's that so much of what he knows is obviously, demonstrably untrue. |
If it helps "data wise" both my wife and I consider the A/C system in the 88 Carrera very compariable to the system in our 01 C4. Last edited by wwest; 05-30-2013 at 05:37 AM.. |
Brando
I was hoping for more though. I think you'r bored and just want to upset the applecart. Listen to me for a second. I'm not stupid, and I'll stretch and say that most the guys here are not stupid. Some have more real world experience than others sure, but you need to step back and let us be. We don't need you. Your "experience" is fine. I'll file it away and keep it for future refrence. And it's there for everyone to search the archives. Just let them be searched. You need to trust me on this, we will get along in the ac world without you. Nothing will happen to us that you need to worry about. Everyone of us make our decisions on our own. Sometimes we make mistakes, but isn't that what life is all about? Leave us alone, we will survive without your invaluable knoweladge on the workings of the ac system and dynamics of heat transfer. I'm intrested to read about ac improvements. I've learned about your all I can stand from you. OK, I'll get a fan. GO AWAY. ![]()
Lol
Banned
nnnn Last edited by wwest; 05-30-2013 at 07:08 AM.. |
So you want to use someone elses car to test your theory? LOL
Volunteer my services to fix a "broken" GTI A/C system, yes, and with great pleasure and satisfaction. If he wished to keep the results totally secret that would be fine by me. For myself the theory is so well founded and the trials so satisfactory that no testing is required. |
Brando
So well founded. That means there IS data?
Banned
Banned
El Duderino
Banned
I have some Monty Python "Holy Grail" quotes all lined up on this one, LOL.
El Duderino
Brando
Hey, this is kinda fun....
I got me some well founded and supremely "founded" scientific theories too. It is scientific if I tested it in my dreams right?
