Phosphate coating prior to powder was mentioned.
In your opinion is an under coat (e.g. zinc phosphate) or other treatment providing additional corrosion protection advisable or needed? Maybe this is on a case by case basis depending on the part and the environment it will likely be subjected to. Thanks.
Sold: 1989 3.2 coupe, 112k miles |
Phosphate definitely has its place but like you mentioned is a case by case need. I would recommend and do phosphate any metal that is Ferrous as it has a higher potential to rust so adding an extra layer of protection doesn't hurt. In addition to phosphating ferrous metals, I always blast as it leaves a far superior profile for powder adhesion.
Byrne Coatings 201-477-0079 chris@byrnecoatings.com http://byrnecoatings.com |
I finished up some '70 Gran Torino parts. Valve covers done in Alien Silver with clear coat. I know they're not Porsche parts but it still shows the potential of what old parts could look like when refinished.
Here is what they looked like when received. ![]() Finished product ![]() ![]()
Hey fellas ists been a while since i posted up. I recently finished or am close to finishing my website and figured I would share with everyone.
Byrne Coatings - Powder Coating, Cerakote, Media Blasting
Fleabit peanut monkey
I had mine done in "chrome" PC and the finish does not stand up well to solvents. Basic gloss black and red seem to be able to take way more abuse without tarnishing.
1981 911SC Targa |
From what you describe it sounds like your chrome powder is oxidizing.
Some more parts refinished.
Custom Drum Hardware
Our new friends at Creation Drum Company are always building some sweet drums for the discerning drummer. They reached out to us recently to do some custom powder coated snare drum hardware. They looked great when completed. http://byrnecoatings.com/custom-drum-hardware/
You need to stick around.
1981 911SC Targa |
Thanks Bob, I intend too.
I would rather be driving
Just looking at the pictures.
The Alien Silver has a green/purple hue that looks like it refracts in the light. You might consider to add this type of hue to a gold base to mimic the yellow zinc plating. My $0.02.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Hey there. You're just down the road from me (2 towns away in fact). I'd love to come by and see your shop some-time. Working on a potential suspension refresh this winter and that'll include a bunch of coated parts I need done.
Bob Kontak's comment referred to this photo:
![]() Quote:
Sherwood |
For some reason my images are not showing only links. I will try and fix.
Yeah the green/purple hue is from the LED lights in my shop. Powder is kinda tricky to try and mix.
Illusion Orange/Black Jack & Clear Powder Coated Rims
Intense Blue Schwinn Frame
I had a couple of questions:
- Which method do you prefer for engine fans - powder or ceramic coating? - Will powder and/or ceramic coating adhere to JB-Weld? I've used it to fill some pitting and chips, but not sure if the either coating will stick to JB-Weld... |
As far as JB Weld goes, I dont believe it will hold up to the curing temps of the powder process. Ceramic coating on the other hand shouldn't be a problem if it is of the air cure type. I should also recommend if anyone is in fact thinking of repairing something that will eventually be powder coated, use a product called Lab Metal. Lab Metal will withstand curing temperatures and has done well by me.
I see you powdercoated springs and wheels...
How does it hold up on a spring? I would think the coating would crack from repetitive flexing? Also, on wheels, does heating them cause any issues? I thought it could weaken the wheel? |
