Honda Comstar Rims
I recently restored some Honda Comstar rims for a custom bike build.
Byrne Coatings 201-477-0079 chris@byrnecoatings.com http://byrnecoatings.com |
High Temp Cerakote
Finished up some exhaust headers. Here's one of them.
Review "Shine Seal" Polishing Sealant
In the spirit of keeping this thread alive
![]() I have always been curious. When one powdercoats, whats the best way to get a "thick" coating? I know that the initla layer is due to electrostatic cling. But, does that attraction of powder to metal continue once the initial layer goes down? I do some rare powdercoating at home, and it seems once you put a thin layer down, the powder is no longer really attracted to the part. And thin podercoating seems to scratch pretty easily. Also, how the heck do you get powder into the small nooks and crevices? Due to the Faraday effect, the powder just doesn't seem to go there... Bo |
Hey Bo,
Thanks for the question. To answer your question, yes the attraction of powder to a base layer is certainly achievable. There are to reasons why multiple coats of powder cause a problem for hobbyists and DIY'rs. First, and most important, you must have a good ground. If you sprayed your first coat and then try to spray a second or multiple coats you must have a spot on the piece to be coated where the metal is bare and still making a good ground. Sometimes I need to use a file to clean up powder where the hook will hang before I spray the next coat. Secondly the Powder Spray Gun that is being used plays a huge part in being able to apply multiple coats. With most hobby guns you can not adjust your amperage and or KV which is necessary in spraying multiple coats effectively. This also holds true for "Faraday Area's". Hope this helps. Let me know if i can help you out with tricks or tips so you can get those multiple coats down. Quote:
BMW E30 Valve Cover Splatter Black
![]() Finished up a BMW E30 Valve Cover in Splatter Black http://byrnecoatings.com/bmw-e30-valve-cover-splatter-black/ Last edited by Byrne Coatings; 10-31-2014 at 12:34 PM.. |
Nice stuff. On that BMW valve cover, is the raised area bare aluminum that's been cleared with PC, or is it colored (silver)? Thanks, John
The raised letters are bare aluminum but they can be done any which way.
Yes we decided to use a metallic gold for the dust shields.
I've had great results with VariPrimer (self etching primer) then simply top coat with paint of your choice. I have door handles done years ago this way that still are perfect and no nicks on them! Cheap simple to do in any garage and looks like paint but very durable. I've also done wheels this way and they hold up very well and never crack and don't chip easily either. The trick is the self etching primer that chemically etches to the metal surface.
Few links with details: Transbond Eastwood Self-Etch Primer Gray The reason it works well is it will not allow moister to get between the primer and the metal, a common cause for some finishes to lift and crack.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Hi!
Great thread! Powder coat calipers, is it possible, i mean due to temp? And how to avoid "Faraday Area's"? Higher or lower amp? Anything special to think about when doing suspension springs? Last edited by Porscher; 01-14-2015 at 12:52 PM.. |
How low can you go on your baking temps for powder coating? I've read that when powder coating aluminum wheels that you want to find a powder-coater who can do a <250deg bake to prevent metallurgical damage.
~Andy
1983 Porsche 911SC Blk/Blk 1956 Ford F1 - Patina 2013 Toyota Tundra 4x4 5.7 2013 Honda Pilot |
BYRNE... this seems a good application for cooling fans. You mentioned much earlier in thread that PCing would be better choice for fans because there are more color choices. Do you have a color chart for Ceracote that can be referenced? (Pardon if you already answered this... I did skip ahead.)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Cerakote is highly rated.
That said, Eastwood has recently announced a product called Exo-Armour Coating: According to claims, it's a two-part, high temp, corrosion-resistant, low gloss, air dry coating to protect painted, bare and polished surfaces. In addition, it can be applied by brush, pad or spray. No affiliation and no independent reviews I could find. Exo-Armour High Temperature Clear Coat Anyone? Sherwood |
Powder Coated Two-Tone Rims
Wow, I love the inside color of that wheel. Is it possible to do an RSR type finish entirely with powdercoat or is the masking required too complex?
So your saying you prefer powder over ceramic coating on headers. Thats hard to believe. I have had heat exchangers powder coated and burn and chip right off header pipes. I dont think it can handle temps up to 1300 deg.F. I am taking a set of early SSI style heat exchangers to have ceramic coated today. Inside and out 3mm thickness silver color.
Great work
I used Christian for my exhaust. He applied Cerokote ceramic coating and they look absolutely beautiful!! Great work and reliable. I am taking a bunch of suspension parts to him to have blasted next..
Thanks |
#byrnecoatings #powdercoating #storefront #customfab #mediablasting #wholefoods #nyc
