1988 Carrera battery replacement
After owning my 88 Carrera for 13 years, my the battery finally took a dump. It is an Interstate MTP-93. Current retail price for this bad boy is $225. Any cheaper alternatives that would be an easy swap. Not interested in an Optima.
Also, at first glance it isn't readily apparent how this thing is held in place. Any tips or pointers to a tech guide greatly appreciated. Mark
Mark 1988 Black on Black coupe |
Now in 993 land ...
I just put an odyssey 925 in my 993. But that's about as much with the adapter. The nice thing with the dry batteries is that you do not have to vent them to the outside.
I have always had good luck with WalMart batteries. EverStart, or as we call them NeverStart jokingly. You can spring for the top model that has 3 year free replacement plus 7 year total prorated replacement. Keep the receipt in the car and you can get a new battery anywhere in the country. Your battery removes with a single bolt holding down the battery at the botom. Check the perimeter of the battery. Also, when you take out the battery, remove the negative terminal first. ![]() Hope this helps. G |
my alternative
http://forums.pelicanparts.com/porsche-911-technical-forum/551173-another-battery-install-thread.html
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Recreational User
If you got 13 years out of the last MTP-93, I don't know why you'd be put off by $225 for another one. The Interstate is as good as any battery you can put in there. Odyssey batteries seem to be good alternatives if weight is an issue, but they won't be much cheaper and require special brackets or adapters to install them.
Not sure why you don't like Optimas. The Red Top is a great battery which I've used for many years. But I wouldn't say it's any better than an Interstate. |
fwiw the modern optimas seem to be nothing compared to years ago. i personally had one fail on me after 7 months and have a few friends who have had similar results. there are many good alternatives for their cost as you are paying a premium for the name.
Get a smaller one. Less PIA getting it in and the re is another threaded hole down there to fasten the hold down clamp.
Ned Nyna 11 87 Carrera Targa 98 528i BMW 2004 Jetta 1.8T |
this thread has some good options -- http://forums.pelicanparts.com/porsche-911-technical-forum/467802-replacement-battery.html
getting close to heading the group 48 agm battery route myself as it will fit in the stock location without mods, is smaller and lighter and uses the Advanced Glass Mat technology so (like an optima,etc.) it won't leak acid. d |
13 years from a battery ? wow that is worth writing to the company about
Member #750 Early911S Registry 1970 911E I know Where Jerry S. has his NYC Garage Yadda Yadda Yadda |
Get this. I have all the records from my 1988 Carrera and I found the receipt for the Interstate. It was purchased June 28, 1999.
![]() ![]() Actually, the reason I was asking about others is the size of this thing. Although it has a handle, it looks like a real PITA to replace. I'm actually quite surprised this battery has lasted this long in Phoenix. But I don't have a ton of starts on this car. Battery replaced with 15k miles, and my car only has 36k miles now.
Mark 1988 Black on Black coupe Last edited by MarkY; 03-15-2014 at 07:17 PM.. Reason: Added second photo |
Now in 993 land ...
That thread indeed has a lot of good info.
I find the stock battery too large and heavy. It was sized for all climates, including Germany. If you don't have any freezing weather starts with the car sitting outside, I believe you can get away with a lot less ... G |
Just bought an Interstate MTP91 for my 1988 Targa from the local Firestone tire store for $129.95. R&Rd it myself. Identical to the old one that lasted 7 years. Heavy, and a tight fit but doable with standard tools. Comes with an attached lifting strap which helps to horse it into place.
1988 Carrera Targa, Guard's Red 1959 356A - long gone 1960 356B - long gone 1978 SC Targa, GP White - Accident - Totaled 2006 (T-boned by a nut on drugs) 2003 VW V6 Passat Wagon |
FWIW, I just went to the Interstate fitment guide. For a SC, it says MTP-49, with a suggested list of $185. Assuming that is the correct fit, I am going to the local Interstate store and doing that.
I have saved this Pelican article for years, but as said in this thread, I am hearing too often that Optima quality is not up to their reputation any longer.
'17 Cayenne |
Ova Day
My '88 had a monster Interstate battery (MTP-93 like yours) that was still good after 10yrs but the PO had installed it without connecting the vent tube. When I started to Autocross the battery started to leak from the vent and caused some minor damage before I discovered the problem. I installed a somewhat smaller Diehard AGM which actually has more capacity. I had to make a very simple custom mount out of a plastic cutting board which is held down with the original clamp. I was also able to use the original battery cables. Here is the one I bought.
Detail of clamp at front. This is the clamp to remove when you pull your battery.
88 Triple Black 911 Carrera Cab, ex Garage Queen 05 BMW E46 M3 21 Tesla Model 3 LR 08 BMW 328xi 15 Ford F150 Last edited by msterling; 03-16-2014 at 08:22 AM.. |
msterling. Very similar to the link I posted. It looks like your setup uses nylon tie-downs that are between the plate and the car. Is that correct?
'17 Cayenne |
Ova Day
I didn't have room on either side of the battery to run fasteners up through the base. The Optima batteries have a base that allows this.
88 Triple Black 911 Carrera Cab, ex Garage Queen 05 BMW E46 M3 21 Tesla Model 3 LR 08 BMW 328xi 15 Ford F150 Last edited by msterling; 03-16-2014 at 08:58 AM.. |
Is very busy
A fellow Porsche owner once told me you can use a motorcycle or gel battery to save weight.
Jason 1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser 1986 944 Turbo (951), 350+hp, Guards Red- Track car 2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver |
Best friend is my dog
I just ordered a new Napa Legend Battery (BAT 9849) which will be in the store this coming Monday. Cost on it was $204 but, is well worth it as this battery has a 75 month warranty and an AGM but, last one went beyond 13 years. The battery weighs in at 58 lbs. but, fits perfect and is a little tricky to install. I use a large piece of thick clear plastic sheeting laid over and down the side of the fuel tank. Keeps the fuel tank from being marred up and battery laid along it will slide in place real easy.
Now in 993 land ...
I am not a fan of plastic or wood tie down adapters. They will hold up fine in normal driving, but if things start moving around in a collision with the fuel tank close by, it can be very bad news. I would only use a metal adapter and also recommend covering the positive terminal with insulation.
HTH, G |
I had an Optima in my former 1987 Targa that begin smoking. Alternator, voltage regulator all were fine. I would not buy one. I have had great luck with Interstate.
1987 928 S4 - Black 2014 C4s 991 - Agate Grey 2014 Cayenne - Mahogany metallic |
