My luck ran out......
aFinally had a car break on the road that I couldn't get home. Top out son and I cruising down the highway 60mph and it dies. I replaced the DME relay, but no goodness. Have already search and am making the jumpers to start testing. After reading up on the problem, I remember getting a whiff of electrical burning while driving. I thought it was a truck in front of us (might just have been my imagination). I will update my findings as I go. Good news the rebuilt engine is using about 1qt of oil per 1K miles, and drives better than it ever has with new Continental tires.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Andy Bullen
ahh sorry to hear it man....
76 912E - Grocery Getter 04 Toyota TacomaTRD - Beater Truck 08 Honda OdysseyEXL - Family Hauler |
PhD on Pending Projects
Coil?
Fuse?
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
Smell= look like DME. Hopefully not .
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
I did visually check the fuses and they all looked good.
I was able to turn the engine over and it would stumble a little and then cut off. I'm leaning towards fuel for now. I did hear the fuel pump whining about a month ago, but it went away.
Looking at fuses is NOT enough, take it out and look at them, sometimes they fall apart when you touch them yet look ok.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
Might be ECU related if you smelled burning.
War Vet
That happened to me once and it was a bad fuel pump.
MattR |
we've all been there waiting for the flatbed. cruising along fine and suddenly she goes t*ts up on ya.
Remember when you fix the problem she'll run even better than before Sent from my iPhone using Tapatalk |
Spiderman
Should start a thread called "flatbed" not to be gruesome. Mine has only ridden once when the Voltage Regulator went bad and overheated the battery, boiled it driving me to the side of the road coughing from acid fumes. Was pre "smart phone with camera". That was a full day replacing the VR in the parking lot of a La Quinta, luckily in shade.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Have you checked out the distributor cap and rotor?
Alternator for me
![]() Sent from my iPhone using Tapatalk |
Fleabit peanut monkey
Is the fuel pump relay a suspect on the 3.2's as with the 3.0's?
Also, ganun is talking sense on the fuses. Find the fuel pump fuse and double check with extreme prejudice (stealing a movie line).
1981 911SC Targa |
I started testing this morning. I made a jumper for the DME relay and turned on the fuel pump. I hear a click when I turn my toggle switch on but no hum from the pump.
I don't have a pressure gauge so I just removed the cap from the test port and turned the pump on again, all I get is a dribble of gas. Since the car was running fine and then died could the fuel filter have stopped up suddenly?
In the 18 years I have had my 911 the one time the DME relay started giving me problems it was like it was trying to warn me. It would cutoff for a moment and then keep running. I swapped the DME relay and all was fine. I got lucky.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Go methodically:
- Ignition to ON and verify the ICV is vibrating - Crank and check fuel pump is running while cranking (DVM on fuse) - Verify you get spark when cranking (old plug against engine GND or inline tester) - Verify you get fuel (negative test: spray starter fluid into intake, or NOID light) Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Ingo, what is the ICV?
I installed the fuel pump and the filter and she started right up. I now have a miss/bucking every now and again. I had that issue after the rebuild, but I thought it was trash in the fuel. When I changed the fuel filter it went away. I'm thinking I may have fouled plug(s) due to me trying to crank it over and over. Will disconnecting the battery cause this?
ICV is idle control valve. Keeps idle speed constant, but probably doesn't have anything to do with your miss. I had a miss that turned out to be a bad ground. I've also had it miss when the battery wasn't fully charged from a defective alternator, so you might check that all your electrical grounds are clean and tight and that battery voltage when running is good. IIRC it should be 13.5 to 14.0.
Happens to the best of us
![]() Mine died on the road, thought it was the fuel pump, swapped it out and got it running again..... Only to have it randomly die again in another drive after about 16 hours on the road. I'm now getting the CDI rebuilt. Fingers crossed.
1973 Coupe Projekt X (AKA bunch o' boxes full of parts) |
