Undocumented User
McLaren-TAG's Avatar
Originally Posted by HawgRyder View Post
This is a never-ending discussion.
Sound is in the ear of the listener.
Power and pitch are as unique to each person as is beauty.
If your system pleases you...great...but your system may sound "tinney" or harsh to the next man.
By all means...find "your" sound...but don't be surprised when some voices his opinion that differs from yours.
Have fun.
Bob
Don't disagree and I said that it's a subjective topic in the opening post, but what I was hoping for is to try and get a clustering of ratings for the community at large. Maybe after there's a couple hundred responses someone with time on their hands or an exhaust OCD would compile the data into a handy dandy chart.
It's already a complicated enough topic when you consider performance. Couple that with the subjective issue of sound and no wonder it's always a hot topic here.
Old 11-07-2014, 04:55 PM
Oh Haha's Avatar
Mine is just right for me. Stock 3.0 Euro spec engine with heat exchangers into a euro premuffler ending in a 1 in 1 out FLO-PRO muffler.
The sound is deep at idle but the pitch increases as the RPMS rise.
No drone at highway speeds. In fact, with the windows up you barely hear the engine sound.
Pacific Blue
Wayne
Old 11-07-2014, 05:12 PM
My 84 911 3.2 is much louder than my stock 996tt. The 911 has SI's and a Dansk sport muffler. It's not bad, but for me, it's too loud. I am going to experiment with Super trapps to see what I can do to tone it down a little, without robbing too much power. If anone has experience I would be interested. Otherwise, I will post m results in the next month or so.
Thanks,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 11-07-2014, 06:16 PM
Derek911's Avatar
Don't forget the sound ratings 1-10. 1 being a mouse pissing on cotton. 10 being a mouse pissing on a woman's bare foot and the ensuing screaming.
Old 11-07-2014, 07:05 PM
jackb911's Avatar
GT3 wasserpumper with Fabspeed center muffler bypass, otherwise stock exhaust.
Reasonable volume below 4.5K in Normal mode.
Screams like a banshee under full throttle at any RPM in Sport mode. Cop magnet.
I'd give it a 9.5
Jack
2007 GT3
gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B
Old 11-07-2014, 08:19 PM
Originally Posted by Hotrod911T View Post
Just right for me. 3.2SS, RarlyL8 1 5/8" headers, Monty 2 in 2 out muffler.
Rod
Hotrod, normally the sump plate drain plug is oriented to the drivers side to avoid pick up tube damage. Your sump plate looks thicker than most so may not be a problem, but just thought I would mention this in case you may have overlooked something.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 11-07-2014, 08:54 PM
3.2 with early heat exchangers dansk sport muffler.
Drone is pretty bad .
'92 968 Coupe
Old 11-07-2014, 09:05 PM
Reiver
Reiver's Avatar
Anyone running a Patrick MSports RSR 2/2 2.25 " outlets with SSI's?
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-07-2014, 09:13 PM
Arrow A little loud.
Rarlyl8 headers with M&k gen V 2 in 2 out, with quiet riot auto sensing baffles matched to a 3.2ss with 46 PMO's, GT2-108 cams.
No drone at all, zero, nada.
Pleasant rumble with a deep throaty growl through 3k, up to 4.5 -5k it increases its note pitch to a symphony of flat six magic edging into a waill of a banshee at 6k plus, everything after 6k is pure harmonic bliss worthy of the mulseene straight.
Old 11-07-2014, 09:15 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
A couple of rules of thumb so to speak:
More turns in the headers = lower tone.
Longer pipes = lower rpm torque.
Heavier metal in the pipes and mufflers = lower sound.
When the exhaust pulses are forced to cross each other it lowers the over-all sound out.
If you apply sound absorbing packing around perforated pipes it will diminish the sound levels...and possibly lower the tone a little too.
How's that for a few rules?
Bob
Bob Hutson
Old 11-07-2014, 10:16 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
My '87 3.2 with stock exhaust was too quiet for me when I first got it.
The Dansk 1-in-2-out (84 mm) and Fabspeed euro muffler is great on back roads and medium to low speeds, but is too loud for sustained highway driving.
It does sound like an old muscle car at low & medium rpm and sounds like a race car at high rpm.
Old 11-08-2014, 07:56 AM
Nice Shane. What are your heater boxes attached to?
Thanks,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 11-08-2014, 08:12 AM
Thanks,
Dave
Nothing, I plan on removing them and plugging the inlets, I just haven't yet.
Old 11-08-2014, 10:28 AM
Elombard's Avatar
3.2 stock internals and chip, RS replica light weight carpet, much of interior is painted with a sound absorbing paint, aftermarket engine sound pad.
I have tried the following combos over the last couple of years.
- stock manifolds, straight pipe/cat delete with M&K 1 in 1 out, pretty loud, ok sound, not sure about cell phone on the freeway, pretty loud for a daily
- B&B headers 1 5/8 2 in 2 out Flow master style with Super trapps welded on both outs, loud , drone and very very heavy. no cell phone use possible on freeway, no way on a daily
- B&B with flow master 2/2 removable cap, loud and big drone, cap did not help much. No cell phone use possible on freeway. barely possible on a daily
- B&B with Magna Flow 2/2 removable cap, less loud and less drone. Still a bit much for a daily, which it is not. Hard to talk on the phone on the freeway but doable.
I wrapped the last 2 mufflers with header wrap and that helps a little.
I also tried the metal flaps trick to separate flow in the 2nd version. It did not have much effect for my set up.
I recently put a large moving blanket in the back draped over the parcel shelf and that helped a little.
I think in the end I am going to get a cheap used stock 2 in 1 out and have it modified to bollt on. I had this on SSIs on a 3.0 on an earlier car and I liked it the best. It noticeably effects power but I will switch to megaphones for the track days.
I will add rankings later, I need to re read how that is supposed to work. I am confused is 10 loud or good or both?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 11-08-2014, 11:32 AM
jackb911's Avatar
I believe it is...
1 = quiet
10 = My neighbors hate me
Either is good depending on personal preference.
Jack
2007 GT3
Old 11-08-2014, 12:05 PM
ganun's Avatar
Rather than a subjective loud, use an app to actually measure the dB.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 11-08-2014, 12:35 PM
gliding_serpent's Avatar
There is a link to a great app on my post here. I am taking note of this thread and will combine 3.2 info with my thread. Lots of great info on this site, just needs to be organized.
http://forums.pelicanparts.com/porsche-911-technical-forum/834369-ultimate-exhaust-resource-3-2-under-construction.html
I think the db readings are key. Otherwise it becomes very subjective. Too much work and no one contributes however...
I thought my exhaust was too loud. Now I think it is just right after a 1000+ miles. My hearing is also noticeably worse. 911 3.2 with cat bypass, and custom bursch 944 muffler. More of a straight pipe. 100db at idle outside of the car. In the car 90 db at idle, and just over 100db on fulll throttle. I have a new M&K 2:1 and SSI's that will be installed over the winter.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 11-08-2014, 03:03 PM
esonefour's Avatar
Mine is loud like pretty much straight pipe loud.
In the progress on making up a custom cross over system with two 350mm resonators.
Will report back early next week.
Definitely keeping the M&K's for track days.
Old 11-08-2014, 03:12 PM
Brew Master
cabmandone's Avatar
I gutted a stock muffler and modified the piping to go up to 2.5" out. It's "throaty" without a lot of drone but my brother says the 4" tip I put on makes it look "ricey". I put the larger tip on because I thought the opening in the rear valance looked out of place so I filled it with a tip. It's got nice rumble at idle and really growls when I jump in the throttle. No pics today but I'll take one and post later.
Almost forgot! I have a cat delete pipe that helps with the growl a little too.
Old 11-08-2014, 04:09 PM
Always Be Fixing Cars
I have to give a big endorsement to the Bursch Quiet Street with cat bypass. It basically just liberates the motor a bit, brings it alive. Adds a bit of bass, some humm, some purring, without ever being intrusive.
It is the only non-stock exhaust setup I have ever had that:
A) my wife and all other laypersons have voluntarily commented on, in the positive
B) has never, even when really tired and in traffic, gotten on my nerves.
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 11-08-2014, 05:42 PM
