Just ordered the rear lights and third brake light sets from spoke. Been concerned for years about someone rear-ending me because the stock lights are fairly dim by today's standards.
'84 Carrera Cabriolet |
New Rear Turn Signals Installed
I wanted to change my stock red rear signal lenses to yellow.
So, I thought to upgrade to Spoke LED while I'm at it. I will post pics , looks way better
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." Last edited by scotricker; 08-23-2020 at 02:48 PM.. |
I guess my gif images won't post.
fixed gifs
original bulb red lens
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
Spoke LED yellow lens
I’m slowly making progress on 3D printed housings. Here are some pics of a half scale printing:
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Oh, I LIKE this! I currently have my rear housings out to clean them up, install new gaskets, etc. They're heavy lil' suckers. I'd be down for a set of lightweight drop-in replacements, stuffed with Spokeworks LED goodness.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Frank, I want to replace the gaskets around the fixtures. How do I remove the housings? I see one screw by the sidemarker. Are these fixtures screwed in from the front or do I need to go behind them?
Find Spoke's LED Products: www.spokeworksled.com |
http://forums.pelicanparts.com/porsche-911-technical-forum/451961-any-tips-successful-removal-tail-light-assembly.html ...good luck!
Same here would love a high quality light weight replacement
Making more headway. The black printing is first prototype and white is second.
AutoBahned
Add me to the lightwt. housing list!
What material is the white one? |
I'm interested also. Please add me.
The white one is ABS. The connecting piece holding the three pieces together isn't installed. That will bring the weight to just under 300 grams. Total print time is over 24 hours!
Sigurd 73.5T 3.2SS EFI X87 944S 3.0 |
Interested.
Sent from my iPhone using Tapatalk |
This is only the running lights, no one to press on the brake pedal:
'84 Carrera Cabriolet Last edited by BE911SC; 10-01-2020 at 08:06 PM.. |
scumbag
Record both levels of lights in same video. During playback, pause video at correct moments. Take screenshot of each.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
1979 911 SC
Just did my brake lights this weekend. Huge improvement and took minutes. Now I have to do every other light in the car! Thanks Spoke!
Excited to see the new brake lights. Purchased a set. Thanks!
