Question Arizona Emissions Test
Hi!
New 911 owner in AZ here. It's an '86 without the original exhaust system and no catalytic converter. I need to get it ready for emissions. Any helpful suggestions are welcome!
Thanks!
86CC
Old 12-17-2015, 09:13 PM
SOAZ's Avatar
Originally Posted by 86CarreraCoupe View Post
Hi!
Thanks!
86CC
Register it more than 25 miles from the nearest MVD testing location and you're exempt from emissions. Prescott, Flagstaff or even an area on the outskirts of Phoenix will qualify.
If you live in the town of Phoenix or Tucson you could try denatured alcohol. A bad person would get the tank very low, add the alcohol and then go to emissions. Pass, and then fill the tank with gas to dilute it. I, of course, would never do this, but you could, if you were a bad person....
DIY: Can't Pass Emissions? Thank goodness for denatured alcohol...
88' 911 Carrera, Sunroof Coupe. Black.
76' FJ40 Land Cruiser
71' BMW R75/5
www.dirtsunrise.com
Old 12-18-2015, 07:09 AM
Barrpete's Avatar
They will check to see if a cat is installed. So you're gonna need to bolt one on at least temporarily. Unless you can register it outside metro Phoenix or Tucson as SOAZ suggested.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 12-18-2015, 07:18 AM
Insure it with one of the collector car insurers like Hagerty. Then change the titling/registration to reflect its collector car status and it will be exempt from emission testing. I found easier to work with one of the franchise titling services rather than the Motor Vehicle Department. The insurance company will notify the MVD when you purchase the insurance. Hagerty calls their insurance classic rather than collector and it was necessary for Hagerty to fax a letter to the titling service explaining that their "classic" was indeed "collector" insurance. Worked for me with my '88 911.
Old 12-18-2015, 08:13 AM
Travis Neff's Avatar
Definitely do the collector insurance, you don't have to do emissions with that coverage.
I did do testing this past year for my SC, no visual test. Even with the aftermarket exhaust you may be just fine. Worst case scenario is you do not pass the test!
72 914-6 GT Conversion 2.7
82 911 SC Coupe
78 SC Targa Hotrod
Old 12-18-2015, 08:57 AM
Reiver
Reiver's Avatar
If you are in Phx call DJ at Jacksons Porsche (indy aircooled shop) and he can analyze your emissions and will tell you if you'll pass....he can tune it to pass more than likely as is.
OTOH, just get collector car insurance and you're exempt.
De Oppresso Liber
Strength and Honor 5th Legion
Old 12-18-2015, 09:54 AM
Josh D's Avatar
Insure and register it as a collector car. I did this with Hagerty insurance and had no problem with the MVD as was stated earlier. Another benefit of registering as a collector car is a 5'year registration.
Old 12-18-2015, 10:29 AM
AZ Smog
They will check for CAT, but have no idea what it looks like. I have run through with CAT bypass, won't pass on HC%. Buy or borrow CAT and install for test, then do 2 year registration.
Old 12-18-2015, 11:03 AM
sc sc is offline
sc's Avatar
My 1979 3.0 911SC with Fabspeed cat bypass and muffler.....has passed visual every year for the past 10 years...the obvious stuff like air pump and or EGR if missing will probably get noticed...on my CIS, I lean it out a tad and bump up the rpm by 800...My HC and CO% have never failed...oh and make sure the car is really warmed up and at temp!
Old 12-18-2015, 11:25 AM
Thanks for all the advice!
Old 12-18-2015, 08:43 PM
Sboxin's Avatar
+2
www.donjacksonent.com/DON JACKSON ENTERPRISES Independent ... Don Jackson Enterprises ~ Porsche Independent Repair & Service 1931 W. North Ln. ~ 602-997-2785.
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 12-18-2015, 09:12 PM
Tags
arizona , emissions
