-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   1972 911T with '86 Turbo Project thread (http://forums.pelicanparts.com/showthread.php?t=921206)
brasch 08-18-2016 06:08 PM
Lots of progress, front suspension pan ready to weld in, other vent welded shut, door bottom ready to weld a patch in, etc
http://forums.pelicanparts.com/uploa...1471572265.jpg
http://forums.pelicanparts.com/uploa...1471572294.jpg
http://forums.pelicanparts.com/uploa...1471572441.jpg
http://forums.pelicanparts.com/uploa...1471572469.jpg
http://forums.pelicanparts.com/uploa...1471572486.jpg
78-911SC 08-18-2016 06:23 PM
Very nice progress. A lot of welding. Keep it up very enjoyable to follow.
brasch 08-24-2016 07:18 PM
Lots of progress, almost ready to epoxy prime everything in white so I can drive and sort out the drivetrain. My dad helped weld tonight while I fabricated mounts, a custom reflector panel, etchttp://forums.pelicanparts.com/uploa...1472095035.jpg
http://forums.pelicanparts.com/uploa...1472095060.jpg
http://forums.pelicanparts.com/uploa...1472095078.jpg
http://forums.pelicanparts.com/uploa...1472095122.jpg
brasch 08-28-2016 05:52 AM
Got some help from my daughter, she's levitating the car for me!! Lol good progress, front suspension pan done, bumper mounts fabricated, bodywork almost done, epoxy priming parts to test install and drive http://forums.pelicanparts.com/uploa...1472392243.jpg
http://forums.pelicanparts.com/uploa...1472392298.jpg
http://forums.pelicanparts.com/uploa...1472392322.jpg
http://forums.pelicanparts.com/uploa...1472392343.jpg
brasch 08-31-2016 04:10 AM
Both vents gone and primed, started and run through the gears. On the ground tonight for a work car show tomorrow. She's starting to look like a car again!
http://forums.pelicanparts.com/uploa...1472645367.jpg
http://forums.pelicanparts.com/uploa...1472645391.jpg
http://forums.pelicanparts.com/uploa...1472645408.jpg
brasch 08-31-2016 08:29 PM
Back on the ground, ready for its first showing at work tomorrow, long way to go but looking so much better!
http://forums.pelicanparts.com/uploa...1472704051.jpg
http://forums.pelicanparts.com/uploa...1472704106.jpg
http://forums.pelicanparts.com/uploa...1472704140.jpg
brasch 09-03-2016 04:27 AM
Lots to still do, but it felt great to get the car out and showing people the progress in two months! http://forums.pelicanparts.com/uploa...1472905587.jpg
http://forums.pelicanparts.com/uploa...1472905610.jpg
http://forums.pelicanparts.com/uploa...1472905641.jpg
brasch 09-03-2016 04:30 AM
Remember 3 months ago I started with this, and some horrible side vents!!!!
http://forums.pelicanparts.com/uploa...1472905810.jpg
brasch 12-25-2016 11:51 AM
Lots to do over the winter, but it's fun to see how far it has come, I've got long-hood parts to bring it back to the correct 1972 look too!
http://forums.pelicanparts.com/uploa...1482698947.jpg
http://forums.pelicanparts.com/uploa...1482698979.jpg
http://forums.pelicanparts.com/uploa...1482699004.jpg
http://forums.pelicanparts.com/uploa...1482699050.jpg
MAH77 12-26-2016 07:15 AM
Nice project, progress looks good
BoxsterGT 12-26-2016 10:17 AM
Nice work brasch bringing back this oldie but goodie.
I have a similar old 74 that I would like to fit a 930 motor into, but wonder about the Duck Tail and Intercooler fitment. Can you tell us what was done to clear this?
Also, the 72 has steel fuel lines through the tunnel. Can you tell us anything about what was done to install the two pumps that feed the turbo motor? I believe you said this was done in Germany years ago.
Len
brasch 12-27-2016 08:02 AM
I'm putting the car back on the hoist tomorrow, I'll take Picts of the dual fuel pump setup then.
Here are some Picts if getting the ducktail to fit with an intercooler, minor tweaks of the fiberglass and removing the rubber on top of the intercooler. Final will be much more finished, but here is the rough version, not much needed to fit
http://forums.pelicanparts.com/uploa...1482858147.JPG
brasch 01-01-2017 05:37 PM
A little New Year day drawing. Trying to work on a t-shirt design/poster for the garage...http://forums.pelicanparts.com/uploa...1483324647.jpg
brasch 02-05-2017 07:37 PM
Lots of hours redoing the electric relays to make the motor run correctly rewarded with a great starting car, a few more electric things to do but getting better!
http://forums.pelicanparts.com/uploa...1486355814.JPG
brasch 02-05-2017 07:39 PM
Working on the brakes and suspension now
http://forums.pelicanparts.com/uploa...1486355921.JPG
brasch 02-25-2017 01:48 PM
All suspension out today, making progress.
Does anyone know what the difference between struts with ball joint pins and a bolt are? I have one of each on the front.
http://forums.pelicanparts.com/uploa...1488062824.JPG
nixtfy 02-25-2017 02:13 PM
Nice project. I like the duck tail on a turbo. Can't wait to see it after the new paint.
brasch 02-26-2017 12:00 PM
Thanks! It's getting fun now that it starts on the first turn of the key.
Can you guys help me? I have two different front struts, both 3" spacing one has a bolt to attach to the ball joint, the other has a pin.
Can I put adjustable Konis in these?
Also I'm changing my front sway bar to a 21mm stock bar, what do I need to do to the shocked?
Here are the Picts of the struts:
http://forums.pelicanparts.com/uploa...1488142754.JPG
911 Rod 02-27-2017 12:48 PM
Very nice. You are saving another one!
brasch 03-17-2017 03:29 AM
I'm still working on all my suspension part rebuilds but my buddy just delivered to me a set of sweet baggo/corn hole boards. Will be great for garage days this summer!
http://forums.pelicanparts.com/uploa...1489750134.JPG
