-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   1972 911T with '86 Turbo Project thread (http://forums.pelicanparts.com/showthread.php?t=921206)
brasch 03-20-2017 07:14 PM
Some great progress on the suspension, blasting, painting and prepping Parts for plating
http://forums.pelicanparts.com/uploa...1490065991.JPG
brasch 03-26-2017 12:20 PM
Lots of painting today, shooting for next weekend reinstall of all the suspension, lots of cleaning and painting to do now on the floor pan before I reinstall the front suspension.http://forums.pelicanparts.com/uploa...1490559463.JPG
brasch 04-02-2017 02:22 PM
Getting the final bits ready to bring to the plater and I finally found a good section of original color, ive seen bits of green here and there but this confirms Viper Green! Guess that's gonna be the final color now...
http://forums.pelicanparts.com/uploa...1491171687.JPG
brasch 04-06-2017 04:59 PM
Got my new hood crest decals today, had to match the one Hans had on the car from the 80s! Saves weight, adds speed! Lol
http://forums.pelicanparts.com/uploa...1491526754.JPG
brasch 04-14-2017 01:40 PM
Some great progress today, steering rack refurbished and new turbo tie rod ends, all parts off to players, rear bushings off, ready to plate& front wheel wells stripped and ready to paint. Should be ready for suspension reinstall next weekend!http://forums.pelicanparts.com/uploa...1492205983.JPG
jsottile 04-19-2017 11:40 PM
Awesome build and great thread. Viper green will be a sweet topcoat to this cool outlaw. Did you find an answer to the ball joint question?
brasch 04-26-2017 06:34 PM
Just got all my parts back from the platers, thanks to a friend I found a local Wisconsin company that did all this for $25!!!
http://forums.pelicanparts.com/uploa...1493260415.JPG
brasch 04-30-2017 03:07 PM
Rear suspension and shocks back in, new bushings will make it drive as nice as it looks... started the front by installing the new 26mm sway bar vs. the stock 15mm... so much more fun putting stuff back together!
The front will look so much better!
http://forums.pelicanparts.com/uploa...1493593420.JPG
The rear looks great too!
http://forums.pelicanparts.com/uploa...1493593532.JPG
brasch 05-06-2017 12:38 PM
Front suspension and steering gear back in with new turbo tie rods. Getting closer to a road test!
http://forums.pelicanparts.com/uploa...1494103049.JPG
Flojo 05-06-2017 01:02 PM
Cool!
Thanks for the update!
brasch 05-13-2017 06:05 PM
Rebuilt Front suspension, struts and new rotors on, added a strut brace too. After some cleanup of the trunk. It's getting there, brakes are next
Sadly Hans the old guy I bought it from came over today, it started great and ran nice, now it starts And then dies in 30 seconds! Ughhhhttp://forums.pelicanparts.com/uploa...1494727529.JPG
brasch 05-14-2017 05:24 PM
Video of Hans hearing the car run for the first time in 20 years! He loved the straight exhaust/zork tube!
https://youtu.be/n-5nQjHaw20
brasch 05-27-2017 05:50 PM
Brakes painted and reinstalled today, everything torqued down and ready to bleed tomorrow. Car won't stay running all of a sudden, starts fine then stalls and the rear pump runs for a bit then stops, runs maybe 30 or 15 seconds...
http://forums.pelicanparts.com/uploa...1495936154.JPG
Mad Max 05-28-2017 05:26 AM
Looks like the perfect project.
David_B 05-28-2017 08:51 AM
Awesome work, I can't wait to see it in viper green.
I am no expert on brakes, but I would think you would want the matching turbo brake calipers in the front. But hey it is easy for me to spend someone else's money :)
Good luck with the motor issue, I have had my fair share of chasing gremlins like that and there is certainly a lot of good knowledge to be had here.
brasch 05-28-2017 10:56 AM
Thanks I'm saving for front turbo calipers, I just bought a pair of Alfa 48mm ones for the front so they will work better when I get them rebuilt, same as S calipers. The rear turbos came with the car :-)
vintagecarlover 05-28-2017 07:07 PM
Great project. Wanna see the process.
brasch 06-13-2017 07:19 PM
Finally got the turbo on all 4 and running right with new fuel pumps and a few tweaks. First drive under full power was fun, still a lot to do, but with the suspension rebuilt, brakes rebuilt and the car running right finally I am getting closer... not to chase down some of the gauge issues and wiring...
Pulling it off the lift for the first time:
https://youtu.be/UdnuV8Q91L0
Driving down the driveway
https://youtu.be/dhX2lqFQY0Q
brasch 06-17-2017 03:27 PM
Lots of progress toda! New wiring for front fuel pump (no back to the future wiring), new Rennshift shifter and coupler in, steering column rebuilt and wheel installed, fixed a rear stuck parking brake & installed my Fabspeed (I think) air filter housing... all in all a productive day! Amazing what the new shifter and coupler does to make shifting feel so much better, I couldn't even find what gear I was in before, now it's like butter!!
http://forums.pelicanparts.com/uploa...1497741931.JPG
rattlsnak 06-18-2017 06:14 PM
That shift knob is, well... interesting..
