-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Cab back to Targa! Project "BugBug" goes back to where he once belonged (http://forums.pelicanparts.com/showthread.php?t=971880)
Tom '74 911 10-03-2017 06:52 PM
Last measurement is cross measurements from the front right outside corner of the rear seat to the centerline of the upper left latch-point on the Targa bar (cross measurements to the same points as 2 posts ago): 1275mm
From here:
http://forums.pelicanparts.com/uploa...1507081893.jpg
To Here:
Speed metal 10-03-2017 08:10 PM
Tom you rock!This bar goes in this week. :)
Got my oil cooler hoses but am beat from riding bike park all day.. Ill slap up some pics tomorrow.
Speed metal 10-05-2017 10:30 PM
Oil cooler hoses installed, filled Bugbug back up with oil. No leaks! Not that Id thought there would be, but nice nonetheless.
So! Temps are wayyy down obviously. Mission accomplished. ;) One more little thing done.
Other small stuff done not mentioned in the "build thread"
-All fuel hoses replaced
-New fuel accumulator
-Valve adjustment
-Turbo covers
-Plugs
-Replaced broken fuse block(Yay! Lights!!)
-New internal Tstat and oil pressure sender(Wrong sender was giving some nutty pressure readings, thanks pelican with the gauge part # the proper sender was provided)
-New temp sender too! Also the wrong sender for the gauge..( The motor is not the original, nor are the gauges. Some fun there, but sorted now.)
-Ripped out all the rear carpet and front mats/bottom carpet. Just old and crappy.
-Replaced a bunch of vacuum lines including brake booster stuff
-New H4 bulbs and a few tail light/marker bulbs
-Tore out cd player and speakers
-Removed the giant tits off the back bumper(Made of lead! haha!)
-Changed out the steering wheel for an older momo I had (The wheel I removed was ricediculous)
-Got the horn working(10 lbs of gravel in the existing horn,swapped out
-Track mats(love dem)
-Removed FG wing that was tired, ugly and probably never fit right
-A ton of cleaning! This car was grubby beyond grubby.. Still not done with cleaning..
But!!
The targa bar is getting welded back where it once belonged on Monday. Paint, Glass etc to follow.I received my trim / seals/ etc for the rear of the car yesterday so no excuses!
Speed metal 10-09-2017 09:25 PM
I'm lucky enough to have a friend who is a bodyman/metal fab guy. Adam at Metalcraft helped build my flared 914 years ago and has turned out a ton of awesome builds since we became neighbors 10 years ago..
http://forums.pelicanparts.com/uploa...1507608826.jpg
We were going to do this at my house, but decided to just do it at my shop.(2 doors down from his shop), then (thankfully) we ended up doing this at his shop this holiday Monday. I was almost worthless, but did buy pizza and took some measurements. ;)
This is how it went.
http://forums.pelicanparts.com/uploa...1507606375.jpg
Yuck! The removal of the cab mounts was ugly. More like the fab was ugly. So it was decided to cut away the inner tub to reveal the bottom of the original Targa bar. Ever wonder how far that bar is welded into the tub? There you have it!
No rust! That's always good.;)
Boxing in the inner support. A ton of cleanup, and welding was done in the adjacent areas to fix up the cab conversion.
This is the "new" bar welded to the old mount. Using Tom's measurements and the top I borrowed, we located/positioned/mounted the bar. This picture the welds have been sanded a bit and primered.
Bad picture! This is the other side, sorry for the quality, but not that exciting anyways. Looks like it should before finishing.
What I still have to snap pics of are the window channel bits, and the final inner skinning of the tub. It looks good!
Is it a Targa yet?? :cool: Damn close.. But I don't think so.. The glass is next. Is it possible to install the glass and pull it right out without damaging the seal? I would like to do this if I can,just for fitment of the glass.
I'm going to tackle the glass seal next. I tried half assedly but need to give it a real go. Its gonna be a real pain if my preliminary attempts are any indication!Haha!
Progress!!!
I almost have myself a Targa.http://forums.pelicanparts.com/suppo...sun_smiley.gif
GeorgeK 10-10-2017 01:17 AM
There is on this forum a very good post of targa window fitting by using ground anchors and a strap to put forward pressure on the glass, that makes pulling the seal in much easier (don't have to press on the glass at the same time).
Dpmulvan 10-10-2017 05:22 AM
Good luck with the glass, it's something you only want to do once.
billybek 10-10-2017 05:44 AM
Maybe turn it into a soft window Targa?
Looks good so far!
Tom '74 911 10-10-2017 12:57 PM
Glad the measurements were helpful; Looks good!
McLovin 10-16-2017 11:26 PM
'Sup?
tdw28210 10-17-2017 04:09 AM
Originally Posted by Speed metal (Post 9758278)
That's it for today! Hoses monday;)
Thanks again for all the pics. Cant wait to weld that bar on.. Its comin!
"Hoses Monday" - is that some sort of holiday in Canada? :D Seriously, nice work and your fellow Canadians continue to perpetuate the stereotype of being sooo damn nice and helpful. (I am sorta envious ;)).
Speed metal 10-17-2017 10:14 AM
Originally Posted by McLovin (Post 9779215)
'Sup?
Well....
Paint! Getting prepped now. H4s and a duck enroute from my man Strudelwagen ,
Signal Orange is the color.👍😎😎 pics of prep later..
Speed metal 10-18-2017 10:03 PM
Last Sunday I dropped the Bug off at Metalcraft.(Look at those hotrod oil lines :P) It was the nicest day in a couple weeks, so the cool temps coupled with no top or rear glass didn't matter. I was too busy having fun:cool: New oil cooler doing its job perfectly.
http://forums.pelicanparts.com/uploa...1508386894.jpg
On the weekend my buddy Strudelwagen said he would send me a ducktail with some H4s. He obviously rules! The duck fits nice, and the headlights beat the crap out of the old sugar scoops. Thanks SF!!!!!
Disassembly, and some body work.
The bug bug was pretty smooth, just lots of clear and paint. Too much clear and paint! at least its not crusty underneath.
Some more sanding and some cookie cutters taking the stage! The speed metal Porsche paint/bodywork wheels in full effect :P
Also, glass out.(windshield! obviously the rear glas was out! haha!, window glass not out) Forgot to mention that. Also the antenna is history. Welded up and gone. New glass on the way and seals, trim from our host. Bug bug is coming along! Check out that hotrod oil cooler:cool:
Orange tomorrow!!!!!!!!!!!
Hellraiser 10-18-2017 11:15 PM
Nice! 😎
Speed metal 10-19-2017 07:53 PM
http://forums.pelicanparts.com/uploa...1508467112.jpg
Masked off! Doors on, that's rightSmileWavy
Hanging Duck
Bug Bug is no longer silver! :D
Duck a l'orange
Quick hood shot
Assembly tomorrow, glass Monday.
I almost have a Targa! :cool: Stoked!
Hellraiser 10-19-2017 11:18 PM
:thumbup:
Speed metal 10-20-2017 10:08 PM
http://forums.pelicanparts.com/uploa...1508561668.jpg
This is way too much fun! Reassembly is going nicely. Glass on Tuesday. All the new trim and seals are going to make everything extra cool.
My beater hotrod almost looks good enough to go to the ball!
I have a cool old grill for the duck somewhere, looking forward to all the trim around the rear window to go on.:) Almost a Targa again:)
Swiss cheesed rear bumper coming soon!:D
This color rules!!!!!!
Jack Stands 10-21-2017 12:20 PM
Do you have the rear window seal? I thought they were NLA?
Speed metal 10-21-2017 03:18 PM
I was able to find one yep.
Speed metal 10-23-2017 08:52 PM
http://forums.pelicanparts.com/uploa...1508816381.jpg
The Bugbug is coming along... That bumper is swiss cheese ! ;) Glass was postponed until tomorrow. Looking forward to the final re Targafying of this car.
Wish me luck!:D I'm close....
Hellraiser 10-23-2017 11:36 PM
Very nice! B)
Flojo 10-24-2017 01:40 AM
great job and nice color!
but, I never understand why body shops never mask off the engine and interior when prepping the body. it gets all dusty!! :confused:
I'd hate that cleaning afterwards if it was my car :fail:
Originally Posted by Speed metal (Post 9782030)
Speed metal 10-24-2017 10:02 PM
Ha! Its insult to injury Flo.. Its ok, Bug bug was born to be dirty!
http://forums.pelicanparts.com/uploa...1508905793.jpg
Crap! Upside-down pic..
The bug is assembled! Glass guy had a hiccup or 4 trying to install the windshield..
So he's bringing in an extra one, presumably in case he breaks the first.:rolleyes:
Bugbug has a buddy! A 74 coupe, its no Targa, but its pretty clean.
http://forums.pelicanparts.com/uploa...1508906092.jpg
The good part of the glass guys visit is that he got the rear seal on, (correctly too!) and it all looks good. This pic has the glass sitting on the tub.. I almost have a Targa!
To be continued.... Tomorrow.... I think.....:D
Hellraiser 10-24-2017 11:10 PM
http://forums.pelicanparts.com/support/smileys/clap.gif
Flojo 10-25-2017 01:27 AM
wow, good progress!
McLovin 10-26-2017 01:28 PM
'Sup?
Looks awesome, but you know it's not "officially" a Targa until that rear glass is firmly affixed! :)
Speed metal 10-26-2017 08:37 PM
Originally Posted by McLovin (Post 9791878)
'Sup?
Yes,yes I agree! As mentioned glass guy had grief with the front glass.. Chinese windshield that was just wrong. He's back tomorrow with a PPG.
Pics to followSmileWavy
964TargaC2 10-27-2017 08:45 AM
Impressive!
Were you able to source a new rear glass seal or did you go with used?
Pedro '84 Coupe 10-28-2017 12:36 PM
Lookin' good!
Speed metal 10-30-2017 11:08 PM
After the original glass guys couldn't even begin to get the trim in the car.. I gave them the option to bail. You have never seen 3 guys faces light up with relief and run for their van as fast. Hilarious but obviously irritating as this cost me a week and a half.:mad:
Anyway... Today the guys that the local Porsche dealers use exclusively came out.
After much pushing, slapping and shoving....
I have a Targa!!!!!!http://forums.pelicanparts.com/suppo...sun_smiley.gifhttp://forums.pelicanparts.com/suppo...sun_smiley.gif http://forums.pelicanparts.com/suppo...sun_smiley.gifBack glass is sealed up, trim is sweet.
http://forums.pelicanparts.com/uploa...1509428038.jpg
Tickled to say the least! It can be done! I cant say I wasn't sweating it a bit, but all the measurements were good within 1mm and the top fit nice, but hey, until that back glass is in....Its no Targa! Really happy;) Here it is cleaned up..
BugBug is officially back to where he once belonged! The Rag That Should Not Be has been banished!
Next is the windshield.. We had some trouble with it, and ran out of time. It almost seems like the seal (OEM) sucks... looking for a Porsche one tomorrow. But! Targa bar trim and seals can go on in the morning. ;););)
rwest 10-31-2017 01:44 AM
Excellent! I'm sure I wasn't the only one with fingers crossed you would get it all set right.
Flojo 10-31-2017 01:54 AM
congrats!!
billybek 10-31-2017 05:46 AM
Very nice!
Good work....
Jack Stands 10-31-2017 09:21 AM
Congratulations! I’m very happy that it all came together as that rear window install seemed very difficult.
Speed metal 11-01-2017 09:49 PM
http://forums.pelicanparts.com/uploa...1509597950.jpg
http://forums.pelicanparts.com/uploa...1509595811.jpg
Fully assembled! Top is tight, and snaps into place nice.
Home! A bit of rain but that's no surprise.;)
Snug like a bug in a rug.:D
http://forums.pelicanparts.com/uploa...1509596355.jpg
Those euro h4s look a ton nicer than the scoops.
Now.... Interior and some other snacky treats over the coming rainy season.
SmileWavy
Hellraiser 11-02-2017 12:21 AM
Wow! I think I'm in Love :p
Well done!
VWLoosenuts 11-02-2017 07:28 AM
nice work!!!!!!
McLovin 11-02-2017 10:28 AM
Bravo!
My current Carrera is a low mileage, original paint, bone stock, mint example (like almost every 911 I've had).
But it will be my last one like that. I'd much rather have something like yours, way more fun!
Speed metal 11-02-2017 12:02 PM
Originally Posted by McLovin (Post 9800577)
Bravo!
The black coupe is sorta like that... Super stock minus wheels, factory color, low miles.. I don't mess with it! The Bug on the other hand.. Its more fun because I can do whatever I want! ;)
Speed metal 11-19-2017 10:04 PM
http://forums.pelicanparts.com/uploa...1511156736.jpg
My first try at installing carpet. A little wavy here and there but a massive improvement over what was there previously.
My inner Targa trim was hashed.. But the aluminum frame and padding was good! I wrapped it up in perlon for the time being. I like it actually.
All the trim pieces and rear inner quarters sourced from the classifieds:cool: ( As well as some nice visors )
http://forums.pelicanparts.com/uploa...1511156828.jpg
Still looking for a drivers side pedal board so I can finish it up.
http://forums.pelicanparts.com/uploa...1511157565.jpg
And the crummy old cards had to go.. These were breezy to install. Appbiz on all accounts. Good stuffSmileWavy
Hellraiser 11-19-2017 11:09 PM
Nice job! :)
