Still here
pmax's Avatar
^^^ I don't see that in the OP's pic
Old 10-29-2017, 01:38 PM
justjones's Avatar
Yep exact same set up on mine, its a modification of the original dizzy that turns the mechanical crank pick up into a digital signal the ECU can use (not an expert). That set of picture just doesn't happen to show it, I can post a picture of it but its already been done above
Old 10-30-2017, 11:34 AM
New-ish 911SC Targa Owner
pampadori's Avatar
THat turned out very well! I have a pretty similar setup but went with Triumph ITBs to save the money ($100 per side on ebay with rails and injectors is hard to beat!).
I'm down on power about 15hp compared to your setup but it might be time to look into SSI exhaust.
Would you care to share your ignition map on this thread?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 10-30-2017, 01:37 PM
Tags
efi , itb , rasant , rasant products
