(man/dude)
Jonny042's Avatar
Originally Posted by chrisbalich View Post
SO EXCITING.
Jelly that thing in there and let's see pics!
Closer.......
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-22-2020, 09:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1121 (permalink)
Runnin on empty
acme911's Avatar
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 04-22-2020, 09:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1122 (permalink)
I'm good with tools.
AG81's Avatar
Looking forward to seeing them touch each other.......
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 04-22-2020, 10:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1123 (permalink)
Competizione's Avatar
I'm looking forward to some far more sordid action.....
Old 04-22-2020, 02:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1124 (permalink)
(man/dude)
Jonny042's Avatar
Haha you guys crack me up.
Just the tip?
Old 04-22-2020, 05:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1125 (permalink)
Shaun @ Tru6's Avatar
So full of awesome!
Tru6 Restoration & Design
Old 04-22-2020, 05:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1126 (permalink)
(man/dude)
Jonny042's Avatar
Ok, well it's a little anticlimactic - more details to share but no time at present. The "lift" went really great. Relaxed, and dare I say easy? New ATV hoist really helped.
(EDIT - Not to say I'm not REALLY excited to have this motor in!)
It's tough to photograph the motor now that it's stuffed in there:
Old 04-22-2020, 05:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1127 (permalink)
(man/dude)
Jonny042's Avatar
Originally Posted by Shaun @ Tru6 View Post
So full of awesome!
Thanks, Shaun!!!
Old 04-22-2020, 05:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1128 (permalink)
scumbag
*like*
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 04-22-2020, 05:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1129 (permalink)
Uncertifiable!!!
Uwon's Avatar
Absolutely perfect! What a milestone!
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 04-23-2020, 03:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1130 (permalink)
Well done Jonny! as always the outcome is fantastic . I love your attention to detail.
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 04-23-2020, 04:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1131 (permalink)
AG81's Avatar
Looks proper sitting in it's new home..... Really like the clean engine bay with no sound pad.
02 996 4S
Old 04-23-2020, 05:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1132 (permalink)
(man/dude)
Jonny042's Avatar
Cheers,
Johan
It certainly is a milestone!!! Thank you.
Yesterday it was almost a shock to walk in and see the motor missing from it's usual spot LOL.
I figured mounting the muffler would be a five minute job, even if I stopped for a break. Boy was I wrong...... turns out it was fouling both bumpers and their position had to be tweaked a bit. Finally got it in with millimeters to spare:
The next 5 minute job was to mount the rear licence panel and bumperettes, of course the panel hit the muffler as well. I had to carefully shape the lower portion to a bit more of a curve to better match the muffler. Again, mm to spare.... I'm going to go back and loosen the front trans crossmember mounts and see if I can't shove the whole works forward a bit. Maybe I'll gain a mm on each of the main mounts, the mount mounting bolts, and the xmember to trans studs.
I was relieved to see that the exhaust outlet matches the cutout in the bumper. May have to trim the tailpipe a bit, looks like a shin banger.
Before I forget, a few quick notes on my method for motor drop/install. I have these enormous 5 ton aluminum jackstands which have at least 4 times the footprint of a regular 1-1/2 stand, so they are super stable. One under each torsion bar. I normally don't worry much about marring the finish on the underside of the spring plate but I wanted to protect them this time. I was tossing around ideas until one day it came to me:
Google, through the power of advertising, one day out of the blue showed me what appeared to be the perfect motor/trans hoist. And it was on sale for $129.00 in Canada which is probably about 75 cents USD.... I'd been using one of the more typical ATV lifts and it was given to me..... and was worth about what I paid for it. It would leak down almost as fast as I could pump it up and made motor lifts far too exciting. The new lift is great, and allows me to support motor and trans in one easy to manage package:
I keep the front of the car low for the first phase of the install, having made sure I have enough lift travel to go the distance by measuring and planning. The low front end gives enough clearance to fit under the rear of the body and also plug the snout of the trans into the tunnel. Then lift the front of the car to level it, pump up the lift, and put in 4 bolts. It really was that easy!
Old 04-23-2020, 06:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1133 (permalink)
Looking amazing, very nicely done.
Do you have the name of or link to the engine hoist you are using? I have seen all the "way too exciting" extractions using floor jacks and 2x4s or motorcycle lift. Seems like $129 well spent.
'95 Coupe (2025-??) '86 Coupe (2021-2025) '82 Targa (2018-2022)
Old 04-23-2020, 07:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1134 (permalink)
I'm in Vancouver and also curious about the hoist. Canadian Tire or Princess Auto?
Old 04-23-2020, 08:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1135 (permalink)
(man/dude)
Jonny042's Avatar
Uhoh..... looks like they are all gone....
https://www.royaldistributing.com/maxx-lift-a12-9010.html
Old 04-23-2020, 05:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1136 (permalink)
Runnin on empty
acme911's Avatar
So beautiful, it hurts!
Old 04-23-2020, 08:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1137 (permalink)
No problem. My buddy is a rep for Kimpex, they probably sold them in originally!
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1138 (permalink)
Flojo's Avatar
this car is getting a unicorn for the shelve…., way too nice to drive…
Nothing, I suppose, but copper coating helps prevent seizing for serviceability, and the fact that the conical nuts are self locking is an added bonus.
The Barrel nuts are also sensitive to stud length - not an issue in this case but can be if you don't get the stud length just so, say when converting from thick flange to thin.
Plus they are only $0.50 each so they can be tossed and replaced with new if/when the heat exchangers are removed.
They are typical to what you'll find on a modern car, for good reasons.
3 good reasons, thanks.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 04-24-2020, 02:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1139 (permalink)
(man/dude)
Jonny042's Avatar
It's a bit odd, the "normal" atv lift that you see from HF, Canadian Tire, etc., everywhere, has clearance issues - even without a muffler you end up needing to have a floor jack supporting the front end of the trans. Plus the one I had leaked down which was interesting.
The one I got does not seem to be ubiquitous in the same way. I found an ebay listing for an identical one:
https://www.ebay.com/itm/Bickers-Solid-Hydraulic-Easy-Use-Motorcycle-and-Atv-Lift-1100lbs-Capacity-Stand-/264618709627
Old 04-24-2020, 05:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1140 (permalink)
