Under the radar
Trackrash's Avatar
Nice work. The light at the end of the tunnel for sure. Can't wait to see it on the road.
Holy cal. 58 pages! You know that requires an index, right?
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-29-2020, 07:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1161 (permalink)
(man/dude)
Jonny042's Avatar
59, now!! All I know is the MFI stuff starts around page 20
Well I'm happy to report I was able to save the spark plug connectors I have, especially considering purchasing anything these days is a challenge (for more than one reason!!!):
1. Spent an hour or so with an inspection camera and various implements to fish the remains of one connector out of my cylinder head.
2. Took 5 of them apart (well, 3 fell apart on their own). Last one wouldn't budge so I guess it passes torture test.
3.uncoiled the spring on the last turn just enough so that it won't fall out of the connector should they happen to fall apart again.
4. tweaked retainer clip so the connector is a bit easier to clip on and off a plug.
5. epoxy the whole works back together and re-install after measuring resistance on each.
Not happy about having to mess around with stuff that's junk, but I feel the fix is permanent and they will last years.
ALSO I think the alternator is ok. Turns out the light is on only after I first start the car, until I rev it up over 1500 or so, then it goes out and stays out? Have to research that one, maybe a loose connection? Come to think of it neither battery post is actually tight.......
Today I looked under the car for leaks,, NONE! Thank God for that!! Re-filled the oil after yesterdays drain while hot - it's surprising how much stayed in the car. I put 9 litres in and I bet only 4 or 5 came out! Never in danger of running low, mind you.
Did the first of many fiddles with the mixture screws, 4 clicks lean on the idle screw brought the AFR to 14.3 at 950RPM but it seems the engine prefers to be a little richer than that at idle. So, what it likes, it will get!
Anyway I'm going to resist the urge to run it too much now that it's good to go for road testing (and a proper break in). Going to concentrate on getting seat belts, seats, and rear windows in!
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-30-2020, 04:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1162 (permalink)
Formerly known as Syzygy
Canada Kev's Avatar
Originally Posted by Focker View Post
I'm in Vancouver and also curious about the hoist. Canadian Tire or Princess Auto?
Originally Posted by Jonny042 View Post
Uhoh..... looks like they are all gone....
https://www.royaldistributing.com/maxx-lift-a12-9010.html
Go to their site and click on the "Notify me when this product is in stock" link and give them your information. I did and got an email a couple days later that they had some again, so I ordered one right away and it is now on it's way to me.
Kevin
Old 04-30-2020, 06:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1163 (permalink)
Jon - I'm in Vancouver with a set of plug wires from my SC. I'm a long way off of driving it, if you need me to send you stuff, happy to get it out to you. Will only take a few days.
Ryan
Old 04-30-2020, 06:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1164 (permalink)
(man/dude)
Jonny042's Avatar
Ryan
Thanks Ryan!!
I am pretty sure I have it fixed up and under control - but I really appreciate the offer!!
Old 04-30-2020, 06:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1165 (permalink)
(man/dude)
Jonny042's Avatar
That's great! Still the same price?? What a bargain.
Old 04-30-2020, 06:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1166 (permalink)
Canada Kev's Avatar
Yeah, $129 or something. At that price I can afford to pick one up now with no specific use in mind at this point.
Kevin
Old 04-30-2020, 06:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1167 (permalink)
(man/dude)
Jonny042's Avatar
Wow, Maybe I'll pick up a spare just to have when the hydraulics give out. Are these things even repairable?
One thing I have read is that "over pumping" like when the jack won't go any higher but you keep trying, is hard on the seals. This one doesn't allow that to happen so maybe it will last better than most?
Old 04-30-2020, 06:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1168 (permalink)
Canada Kev's Avatar
It was CAD 129.88. So that's what, about $22 in US dollars?
Kevin
Old 04-30-2020, 08:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1169 (permalink)
(man/dude)
Jonny042's Avatar
Door pocket covered
Here's a hilariously terrible pic of the driver's side door pocket, covered in vinyl.
The door top, handle and lid, and pocket, all have the same smooth/glossy vinyl surface to match the dash/kneepads etc. and this all extends back into the rear of the car where the side panels and rear deck are all finished in the same materials.
I really am having trouble taking a pic that would do this justice.
In other news, I've been unsuccessful in resisting the urge to start and run the car. All I've really proven is that it starts, and runs. Better get to work putting it together so I can prove that it drives!!!
Later!
Old 05-02-2020, 06:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1170 (permalink)
(man/dude)
Jonny042's Avatar
Interior
Slowly getting the interior together. Been working full time on the car trying to get it together. I really want to get it all done with no loose ends before shakedown and break in.
Carpeting is in, I'd rather beat my head against a wall for 2 days straight that do carpet in a 911. It's like spending a few days trying to fit square and rectangular pegs in round holes. I managed to do a pretty decent job, if I don't say so myself, but it's hard not to get stuck on every little wrinkle. They seem to become less noticeable, the more interior stuff goes in. Or maybe it's the fumes from the glue!!
I'm reminded of why I did RS door panels and RS carpet and seat delete in the Rot Rod. I was probably done the whole job in the time it took me to do one door on this car!!!
This car is a full fat, full flavor, version of the 911 recipe. Rear seats and all. Today I wrapped up the seats install and attached the leather retaining straps for the seat backs, the luggage hooks on the rear deck, rear panel install, and ended up figuring out the seat mounting. A good day, and not a whiff of glue!!
The interior work is so worth it, I was not prepared how much work it is, but also didn't realize how satisfying it would be to get it together. The Salt and Pepper Hargaarn wool carpet is a slightly lighter shade of dark and plays off the contrast of the shiny black vinyl and the basket weave on the flat side panels and dash and seats. It really does look like a million bucks!!
Old 05-06-2020, 05:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1171 (permalink)
Canada Kev's Avatar
Yep, it most certainly does.
Kevin
Old 05-06-2020, 07:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1172 (permalink)
Uncertifiable!!!
Uwon's Avatar
Outstanding! Waiting anxiously for pics of the front interior.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 05-07-2020, 03:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1173 (permalink)
(man/dude)
Jonny042's Avatar
Well, Canadian bucks, at least....
Seriously, don't want to sound too pleased with myself, but goddamnit it's gorgeous!
Old 05-07-2020, 04:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1174 (permalink)
Carrera 3.2 Targa
Goddammit, it's gorgeous...
1971 911T
2016 Boxster
1988 Vanagon (crashed)
1985 Carrera Targa (Sold)
1970 VW Beetle
Old 05-07-2020, 07:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1175 (permalink)
nene's Avatar
It appears to be coming straight OUTTA the DEALERSIHIP!
Just Fantabulous!
Old 05-07-2020, 08:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1176 (permalink)
Hi Jonny,
What window winder did you use?
Dan
Sent from my Nokia 7.1 using Tapatalk
Old 05-07-2020, 09:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1177 (permalink)
(man/dude)
Jonny042's Avatar
You mean the handle? It's a reproduction one, IIRC. I think it might actually be a URO part. Quality is good.
Old 05-07-2020, 09:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1178 (permalink)
(man/dude)
Jonny042's Avatar
Cheers,
Johan
Voila!!
I'm leading with this photo (more later) because it's really hard to capture the true look of the interior with my crappy phone. This picture does a pretty good job of it. Plus it's the view from the drivers seat!
Old 05-08-2020, 07:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1179 (permalink)
(man/dude)
Jonny042's Avatar
OK, one more....
Old 05-08-2020, 07:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1180 (permalink)
