(man/dude)
Closer.......
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Runnin on empty
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff. https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html |
I'm good with tools.
Looking forward to seeing them touch each other.......
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
I'm looking forward to some far more sordid action.....
(man/dude)
Haha you guys crack me up.
Just the tip? ![]()
So full of awesome!
Tru6 Restoration & Design |
(man/dude)
Ok, well it's a little anticlimactic - more details to share but no time at present. The "lift" went really great. Relaxed, and dare I say easy? New ATV hoist really helped.
(EDIT - Not to say I'm not REALLY excited to have this motor in!) ![]() It's tough to photograph the motor now that it's stuffed in there: ![]() ![]()
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 04-22-2020 at 05:42 PM.. |
(man/dude)
scumbag
*like*
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
Uncertifiable!!!
Absolutely perfect! What a milestone!
Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Well done Jonny! as always the outcome is fantastic . I love your attention to detail.
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Looks proper sitting in it's new home..... Really like the clean engine bay with no sound pad.
(man/dude)
It certainly is a milestone!!! Thank you.
Yesterday it was almost a shock to walk in and see the motor missing from it's usual spot LOL. I figured mounting the muffler would be a five minute job, even if I stopped for a break. Boy was I wrong...... turns out it was fouling both bumpers and their position had to be tweaked a bit. Finally got it in with millimeters to spare: ![]() The next 5 minute job was to mount the rear licence panel and bumperettes, of course the panel hit the muffler as well. I had to carefully shape the lower portion to a bit more of a curve to better match the muffler. Again, mm to spare.... I'm going to go back and loosen the front trans crossmember mounts and see if I can't shove the whole works forward a bit. Maybe I'll gain a mm on each of the main mounts, the mount mounting bolts, and the xmember to trans studs. I was relieved to see that the exhaust outlet matches the cutout in the bumper. May have to trim the tailpipe a bit, looks like a shin banger. ![]() Before I forget, a few quick notes on my method for motor drop/install. I have these enormous 5 ton aluminum jackstands which have at least 4 times the footprint of a regular 1-1/2 stand, so they are super stable. One under each torsion bar. I normally don't worry much about marring the finish on the underside of the spring plate but I wanted to protect them this time. I was tossing around ideas until one day it came to me: ![]() Google, through the power of advertising, one day out of the blue showed me what appeared to be the perfect motor/trans hoist. And it was on sale for $129.00 in Canada which is probably about 75 cents USD.... I'd been using one of the more typical ATV lifts and it was given to me..... and was worth about what I paid for it. It would leak down almost as fast as I could pump it up and made motor lifts far too exciting. The new lift is great, and allows me to support motor and trans in one easy to manage package: ![]() I keep the front of the car low for the first phase of the install, having made sure I have enough lift travel to go the distance by measuring and planning. The low front end gives enough clearance to fit under the rear of the body and also plug the snout of the trans into the tunnel. Then lift the front of the car to level it, pump up the lift, and put in 4 bolts. It really was that easy!
Looking amazing, very nicely done.
Do you have the name of or link to the engine hoist you are using? I have seen all the "way too exciting" extractions using floor jacks and 2x4s or motorcycle lift. Seems like $129 well spent.
'95 Coupe (2025-??) '86 Coupe (2021-2025) '82 Targa (2018-2022) |
I'm in Vancouver and also curious about the hoist. Canadian Tire or Princess Auto?
(man/dude)
Uhoh..... looks like they are all gone....
https://www.royaldistributing.com/maxx-lift-a12-9010.html
Runnin on empty
So beautiful, it hurts!
this car is getting a unicorn for the shelve…., way too nice to drive…
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
(man/dude)
![]() The one I got does not seem to be ubiquitous in the same way. I found an ebay listing for an identical one:
