Chin Spoiler Without a Tail
Hell all,
I’m sure there have been threads on this subject but I haven’t seen them. I have an 84 911 cab. It’s a standard narrow body without a tail. I put 9 inch Fuchs in the rear and 7’s on the front and I like the “heavier” look that this affords the car. I have been contemplating putting a chin spoiler on the car but am unsure how this will effect things. I know with a chin spoiler that you are really supposed to have a tail but for for a narrow body car I don’t prefer a tail. Anyway, has anyone done this? Ie chin spoiler and no tail. Could you post a pic? Did you like it? Any adverse effects?? Positive effects. |
did it, no adverse effects, think it looks better too
I think the problem is when people put a whale tail on the car without a front spoiler..
1987 Porsche 911 Carrera Coupe |
It will definitely change the aero balance of the car by effectively adding downforce to the front and reducing air pressure under the car. Whether your car will become "unbalanced" can only be determined in a wind tunnel or on a race track at high speed. If you never go above 80mph you will never notice a difference. At 140 it may be a different story.
2021 Cayman GTS 4.0L 2020 Macan (dog hauler) |
@60mph front lift goes from 20# to 2# w/ the lip spoiler, rear stays the same 44# @125mph front lift goes from 80# to 7#, rear stays the same so you have more grip in front, rear stays the same 176# lift
Goldfinger
1984-Carrera (pewter metallic) Last edited by Mattcamp; 04-27-2018 at 02:56 PM.. Reason: answer to original poster question |
Still here
Bear in mind all these are coupe numbers.
I have never found any for the open tops. And yes, prefer the clean tailless look as well. |
Roof off + windows up improves things immeasurably
I liked the look of a chin spoiler without a tail too... Car looks less "delicate" or something with it on. I think longhoods look better with the delicate look to me, while impact-bumpered cars look better suited to the "heavier" look you mentioned. Car was noticeably more stable at highway speeds- haven't been beyond that, so can't comment on stability at track speeds. More food for thought...
1983 Porsche 911SC 2004 Volkswagen MkIV R32 "Excuses are the nails holding together the house of failure." |
Actually, when I get over like 90, I can feel the front lift abs get lighter. I’ll bet the chin spoiler will at the very least reduce this. Ok. Thanks guys. I’ve made up my mind, I’m doing it!!!!! I have the engine out and doing a bunch of work right now. I’ll post pictures once it’s all done!!!
Fleabit peanut monkey
Does it disturb air mid car to reduce lift on the rear?
1981 911SC Targa |
I as a Targa owner haven’t noticed a significant handling difference on the road without the top on. However I’m turbocharged and have noticed my intake air temperatures are roughly 3-5 degrees Celsius hotter with the roof off.
1987 CherryRot Targa: stock 3.2, Presicion Turbo 5976, custom intercooler(made at home), Tial 44mm wastegate, Walbro 255 in-line, Aeromotive fpr, Seimens Deka60 injectors, RarelyL8 headers, DiyAutotune boost control solenoid, Coil on plug, MS3Pro, running .5 bar currently |
case 1: roof off and windows down, the spoilers still work pretty much as usual but total drag goes way up, this is the worst case scenario
case 2: roof off w/ windows up drag goes way down, not as low as all closed up but not too bad either, spoilers function as usual case3: roof on w/ windows down drag is higher than all closed up, somewhere in between case 1 & 2. A similar thing happens w/ coupes w/ windows down, drag goes up and spoilers work as usual
You wouldn't notice it as a driver, the drag goes up, much more so w/ windows down and roof off, but some w/ roof off and windows up(the low pressure area where the roof was mostly pulls air from the cockpit w/ the streamline flow pretty much undisturbed). The motor just has to work a bit harder for the same speed.
MBruns for President
I ran at Sebring for a number of years - chin spoiler - no tail -
No adverse effects - car was more planted on the high speed sweepers (BTW - Sebring is a fast track - if there were handling issues, they would have been uncovered)
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Under the radar
A duck tale will solve the problem.
It looks great with just a chin spoiler. Debating on doing this look as well!
23 Macan GTS 97 240SX 94 Land Cruiser Too many Miata's to count. |
911T '72
I added a factory front chin spoiler because I just don't like the look without one. I'm not a fan of whaile-tales. So this is how I run. I've done quite a few runs of +120 mph runs on the autobahn and it feels planted. Doing these speeds in my '72 911T is scary, not so in the carrera.
Dennis Good drivers have dead flies on the side windows. (Walter Röhrl) Last edited by DeRRis; 04-27-2018 at 09:27 PM.. |
911T '72
Dennis Good drivers have dead flies on the side windows. (Walter Röhrl) |
As per pic, chin spoiler and no tail. I've had my car up to 135mph and it felt rock solid. and around fast sweepers at 100mph.
