Bronze shift bushing, What a difference!
Well, I finally got around to installing one of those bronze shift bushings at the trannie. I got it for christmas this year, boy this thing is the best thing since sliced bread! What a difference it makes! I have all new plastic bushings but the one at the trannie fits very sloppy. With the bronze one now it really shifts sweet and tight! Now other people will be able to shift the car...
I should have put it in sooner! Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression) www.914Club.com My Gallery Page |
Geoff,
Is the bronze bushing identical to the plastic? I noticed my plastic one seems to have some play. The one that is in the firewall also has some play. Does that one come in bronze also? Thanks,
Gerard 74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
No, it doesn't look like the plastic bushing at all other than it has a hole in it. It is solid bronze with a shoulder and a grove for a snap ring. It is fairly tight fit the shift rod. It was only $25
I have not seen one for the firewall yet. Geoff
Hey! Nice Rack! "Celette"
I'm rebuilding my shift rods. and installing liniar bearings inplace of the plastic bushing. I bought a set with the correct size shaft. These bearings move circlular and liniar at the same time. I'll let you know how it works out.
914 Geek
I've had two interesting problems with the bushing on the side-shifter console. The first was that the plastic bushing would slide up and down--the hole that it mounts in has been oval'ed out. The second problem is that the rear shift rod has been necked down from wear.
Both contribute significantly to slop. I epoxied the bushing into the side-shifter console, and that helped a lot. I will eventually be replacing the rear shift rod completely, but the replacement that I bought does not quite fit on the front shift rod... The hole in the coupler is a little too snug to let it get completely seated. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Where can you get that bronze bushing???
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
914 Geek
"Just because it isn't in the on-line catalog doesn't mean we don't carry it."
Call 888/280-7799, talk to the sales guys. Tell them that you want the bronze shifter bushing that you read about in the shifter improvements tech article. They should be able to find them. --DD
