Gold83's Avatar
Send a message via AIM to Gold83
Unhappy Starting problems, wire boot corrosion
Hello, I'm a new member but longtime reader of the forum.
My '83 944 w/ 95, 500 miles was operating perfectly, but on a humid day when I tried to start up it cranked but would not start. I went back to it later in the day, and it started but with a weird sparking sound. After starting it ran normally. Now it refuses to start in all but dry, warm conditions (weird).
Pulled wire caps: cylinder 1 perfect, 2 slight darkening of cap metal and plug cap, 3 gray ashy corrosive look, 4 light colored ashy corrosion. I have relatively knew wires and bosch platinum 4 plugs.
What's up? I suspect I just need new wires and plugs. Anyone know what's up here?
ALSO: I'm about to change the fuel filter and oxygen sensor. Is it as easy as it seems? I'm not very experienced working on cars.
Thanks a lot
'83 944 - b/c power steering is just extra weight
Brown interior with khaki pinstripes
5 spd.
Old 06-26-2004, 05:14 PM
AFJuvat's Avatar
Definately get new plugs and wires - new cap and rotor will not hurt either.
Fuel filter and O2 sensor are not difficult - make sure the car is well supported when youare under there
o2 sensor - 22mm
Fuel filter 17 and 19 mm - you will need 2 19mm wrenches.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-26-2004, 06:04 PM
Gold83's Avatar
Thanks AFJuvat!
5 spd.
Old 06-27-2004, 07:57 AM
SoCal Driver's Avatar
Don't forget to clamp the fuel lines.
Don't loose the stoffenduffus washer.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-27-2004, 08:13 AM
