Driver
BIG question
Sorry about this but here goes:
Can anyone provide a complete list of everything I must buy for an engine rebuild?
I mean every last flange, seal, plug etc.
Assume I do not need new pistons, but everything else for a rebuild.
Thank a lot.
GHEN
'87 944
Old 02-21-2005, 03:21 PM
Send a message via AIM to Trevor
Wow, I think Vertex has a kit.
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 02-21-2005, 03:23 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
yeah, that is a BIG question.... someone just posted asking about this on rennlist, do a search, decided that a rebuild kit was the best route...
also, do your clutch et.c while you can
and replace all hoses etc.
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 02-21-2005, 03:28 PM
Driver
But there is no list of what comes in it.
Thanks though.
GHEN
'87 944
Thats a lot to ask but here goes:
- buy a new 944
Old 02-21-2005, 03:38 PM
A WHOLE BUNCH OF STUFF!!! THEN WHEN YOU THINK YOU'VE GOT IT ALL YOU WILL NOT. I now that doesn't help, but what you have to ask yourself is do you want to really get it right or just get it running again. You WILL catch yourself saying "well I might as well do that while I have it apart".
Old 02-21-2005, 03:40 PM
those darned while your in there things, my car is a prime example of that!
way too much $$$ but its worth it, sorta...
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 02-21-2005, 03:46 PM
Really depends on how deep you want to rebuild it. Generally a headset and pan set will contain most gaskets/seals. But then you need all of the little pesky parts such as balance shaft o-rings, plugs, etc....A rebuild is not one of those things that you can plan exactly right. More like set aside a week or 2, make room in your work area, and go through your motor to see what needs replacing and what does not. and dig into it. Take your time and things will come out right. Have a good manual that breaks everything down to the nitty gritty would be a good start. Heck, I still have the OLD Euroselect Porsche parts book for water cooled Porsches
which breaks down the parts pretty good.
I have known some that have rebuilt the 44 motor while the block was IN the car. Just removed the heads and the oil pan. Not the way to do it IMO. Takes too much time. Seen others just install a head set and called it a rebuilt motor.
Lee
1998 supercharged GS400 with NAV & everything else, approx. 470-490hp.
Prior
944 NA-November 1996 issue of European Magazine-page 24, 944 turbo (2), 928 (2), 924s(plenty), 911 turbo-1979, various others.
Old 02-21-2005, 07:46 PM
Driver
Perhaps I should have phrased my question a little better.
I am having my engine re-built by an experienced Porsche mechanic.
I have a great friend (different guy) from whom I get a very good discount on Porsche parts.
The mechanic has quoted me 2 prices (at my request) One price is the complete price, the other is the labor only price.
I was hoping if I could figure out what parts I need I could figure out if it was more economical to buy the parts myself, or just pay the mechanic for the whole shebang.
GHEN
'87 944
Old 02-21-2005, 08:02 PM
Ghen, let me ask. Why are you rebuilding ot begin with?
Lee
Prior
Old 02-21-2005, 08:05 PM
Driver
Leaks down the bottom, valve problems up top, history too murky to let me feel good about anything but a total re-build.
I plan on driving it for a looong time, so the cost of the build will be amortized over more than a couple of years.
Plus the car makes me grin when I drive it, I love it too much to let it die.
GHEN
'87 944
Old 02-21-2005, 08:27 PM
What you could do is to purchase the major items you know you will need upfront to save on parts. Then as time goes by your mechanic should hopefully keep you in the loop as to what is required next.
If you do not have access to a nice engine breakdown of parts with related part numbers I would be happy to scan a few pages and post for you. Keep in mind that many of these part numbers have probably been superseded but I am sure Porsche would have that information already.
Things that come to mind are, ok here we go:
Head gasket
Cam housing gasket
Valve stem seals
Rear cam housing gasket
water outlet gasket
water pump & gasket (might as well put in a new one with all of the rollers/tensioners)
Temp sensor bracket gasket
Valve Guides?
Valve springs if they are not up to snuff
crank seals front and rear
balance shaft bearings, seals and o rings (clear flat o ring that easily breaks). Be VERY careful removing the balance shaft bearing caps as they break easily and are matched (cut) from the block. Very very hard to locate another EXACT cut piece. I once went through over 13 in a salvage yards box of them to find one that worked!
Main and rod bearings
Fuel injector seals
New o rings/washers for regulators
oil cooler gasket kit
Engine mounts?
Clutch?
piston rings
connecting rod bearings
any of those hoses underneath the manifold that are a pain to get to once installed
O rings for oil filler tube assembly, oil pressure reg. ,
plus all belts, hoses, etc...
Sorry but that is all I can think of off the top of my head-been 7+ years since a 944 engine rebuild . Did about 7-9 of them over my 44 experience. (not the same car of course) Did some overflow work for a local Porsche garage. They did not care to work on 44's so I grabbed those for an easy (yeah right) buck.
Since the engine will be out, time to grab some solvent and clean clean clean that bad boy as you may not (hopefully) get another shot at reaching some of those spots.
Like I said I would be happy to email you some pics of the engine breakdowns for different years with pics
Lee Dye
Prior
Old 02-21-2005, 09:31 PM
Driver
Lee,
Thank you very much, that is very cool of you.
I don't think I'll need the pics, as I am not doing the re-build, but I appreciate the offer.
Thanks again,
GHEN
'87 944
Old 02-21-2005, 09:42 PM
Your welcome. Take some pics too. They are nice to look at down the line when you baby is running the way you want it
Lee
Prior
Old 02-21-2005, 09:48 PM
livewirevoodoo's Avatar
GHEN - you need to get your hands on a copy of the porsche PET catalouge.. breaks everything in the car down by group with all the part #s..
shows exploded views of all mechanical parts, clicking on a part brings up part #, etc... very handy
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 02-21-2005, 11:19 PM
Driver
Last time I took pics I got depressed
http://forums.pelicanparts.com/showthread.php?threadid=176921
But you are right, (trudges slowly to the garage...camera in hand) I'll appreciate the pictures later.
'87 944
Old 02-22-2005, 08:30 AM
Zero10's Avatar
Send a message via ICQ to Zero10
If you think you have everything you will need, you'll still end up having to buy a few parts. I'm starting with a complete rebuild kit from Vertex, and then as I build, seeing what else I need.
The thread on rennlist I believe was mine, and the general consensus was to just buy a rebuild kit, and go from there. I have lots of time, so I can afford to wait while parts come in.
Now, you are presuming that your cylinders will be in good shape, which mine were not. Something to check on.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 02-22-2005, 09:41 AM
No, don't do it. Don't get married. Oh, sorry, you didn't mean that Big Question...
Red 1967 Saab "96", needs help
Blue 2002 Pathfinder SE
1991 240SX-SE, auto, trans was shot - junked it
Old 02-22-2005, 06:09 PM
There is a 944 engine on e-bay, says it is rebuilt by Broadfoot. The current high but is $975 and supposedly comes with a 12 month warranty. They want an additional $800 which is refunded when you send them your rebuildable old engine.
Just a thought...
Bob S. former owner of a 1984 silver 944
Old 02-22-2005, 11:55 PM
renegademike928
Guest
Posts: n/a
anybody have chassis specs on a 87 earo spec 944? let me know ... pics of the crossmember would help, and any idea about the thicker? heavier duty frame? its just what we hear, and i dont know so i ask... let me know. thank you
Mike
Old 02-23-2005, 01:07 AM
