Rrrockhound's Avatar
Cruise control overrevved!
I was on one of those high-speed roads with occasional traffic lights and when the light turned red, I shifted into neutral in preparation to stop. Didn't realize the cruise wouldn't disengage in neutral and the engine spun into the stratosphere! I don't know why I didn't just think to touch the brake pedal, but in full panic mode, I killed the ignition and coasted down. On restart, everything ran OK, no nasty noises, and the engine runs fine now. I assume there's a rev limiter, and if I hit redline, it wasn't for more than 1 second. Anyway, is there anything I should do or check at this point, like the timing belt tension? The timing belt has probably less than 1K miles on it now.
Old 06-19-2006, 04:43 PM
That Guy
Techno Duck's Avatar
As long as it wasnt a downshift, the rev limiter should have prevented any damage being done to the engine. If you downshift and over rev the engine, the rev limiter dosent do anything.
I wouldnt worry about it.. i have tapped the rev limiter on more than a few occasions (autocross). Still running strong... ::Knocks on wood::
You should have your timing belt retensioned soon anyhow.. supposed to be between 1000-1500 miles for a new belt.
Besides, its good to give the car a good Italian tune up every once in a while.. need to burn off some of that carbon buildup you know.. .
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 06-19-2006, 05:07 PM
Interesting...
Mine only engages ABOVE 80 MPH...
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 06-19-2006, 06:28 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Mine will engage at 20mph if I use it, but it cuts out as soon as I press on the clutch or the brake.
Sounds like your clutch switch is shot.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 06-19-2006, 06:49 PM
Ornery Bastard
Properly functioning 944 cruise control should re-engage when you take your foot off the clutch pedal.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 06-19-2006, 07:01 PM
I think that's what happened...the cruise disengaged when I hit the clutch pedal, but re-engaged when I shifted into neutral and took my foot off the pedal. I checked the owner's manual and it warns against shifting into neutral with the cruise on. D'ohh! I didn't expect it, because my '83 Volvo would disengage if you shifted into neutral, so I assumed a Porsche would, too.
Old 06-19-2006, 07:20 PM
Send a message via AIM to Jer944
the person that had the car disconnected mine cant wait to find out why once the motor is hooked back up
-Silver 85/2 944-
Old 06-19-2006, 07:49 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
LOL!!! There's a rev. limiter. Assuming it's working properly you've got nothing to worry about.
Just a heads-up, in a lot of states it's actually illegal to coast in neutral. In any case, it really isn't the best driving technique.
Black Cars Matter
Old 06-20-2006, 06:16 AM
Ornery Bastard
Agreed. I usually just leave it in gear until I've slowed to idle speed in that gear, then hold the clutch down until I'm completely stopped, shifting into 1st just as the car gets stopped.
Old 06-20-2006, 09:05 AM
Burn the fire.
Brando's Avatar
How can they prove you were coasting in nuetral, when you actually could have been in gear with the clutch in? oooooooo...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 06-20-2006, 11:33 AM
bearone2's Avatar
Question
yes it should but he stated he put it in neutral with cruise engaged which puts the motor in a severe no-load condition.
not sure i want to put all my faith in the overspeed limit capabilities which is protection in a loaded condition.
87951
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 06-20-2006, 01:06 PM
Ornery Bastard
87951
Then don't put the car in neutral and let off the clutch with the cruise control on.
The system functioned as designed. The fault was in the driver.
Old 06-20-2006, 08:18 PM
Haha yeah I kinda did the same thing before in an old Fold conversion van. The cruise control got stuck on at 70mph, and I couldn't turn it off by pushing the brakes or the button. I was left with the only choice of throwing it into neutral, at which point I thought my engine was going to explode like you did. I also killed the engine, but that made it very difficult to maneuver the beastly vehicle around the traffic jam that I was quickly approaching
I would think that everything would be fine with your engine, assuming that your rev limiter is functioning properly. Definitely won't be making that mistake again now will you
'84 944, '05 GTO
Old 06-20-2006, 09:30 PM
Eldorado's Avatar
why would it be illegal to coast?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-20-2006, 10:34 PM
Ornery Bastard
Because it stops engine braking and also makes it difficult to speed up quickly if that is needed.
Old 06-21-2006, 09:29 AM
I can't believe new vehicles would be designed this way, and like I said, my '83 Volvo wagon (god, I loved that car!) would shut the cruise down permanently if you hit the clutch, so I may just look into splicing the clutch shut-off switch so it's on the same circuit as the brake pedal shut-off switch, to make sure this never happens again. Or I could re-train myself not to shift into neutral until stopped... Hmmm...re-wire or retrain self? Better re-wire.
Old 06-21-2006, 04:16 PM
Zero10's Avatar
I tested mine, and it doesn't re-engage when I release the clutch, in gear or in neutral.
Either somebody already tweaked the clutch switch wiring, or mine's just plain broken
Buy my parts!
Old 06-22-2006, 04:32 PM
