Broken Alt tie rod : (
So I finally get the head rebuilt,Belts and rollers done, replaced all vacuum lines with a Lindsey racing kit, installed an upgraded headlight wiring harness and put it all back together.... Took one very long deep breath (this is the first car, let alone Porsche 944 I have ever worked) turned the key and.... It din't even blow up or catch fire! lol
It did however have a "that s just not quite right" sound to it coming from what I thought was belt rollers. I localized the sound to the alt tie rod tension do hicky. Which was broken at the threads closest to the passenger side. So my question is what would have cause this? It was fine after I tightened the belts and I'm pretty sure its was not to tight. I can just turn it a little over 90 deg by hand. Also does anybody have a spare they could/would part with? ![]() part number 944-126-021-03-M100 Thanks for the input in advance Sorry for the long winded post!
Jordan 86 944 n/a Bought to drive...now project 84 944 n/a Bought to feed project... Now I want to fix it! |
Custom User Title
That's a turnbuckle. Never seen one break on the threads like that. I really can't imagine how a break like that could occur. Looks like it just sheared. Metal fatigue?
I bent mine up and had to replace it (the center section is just hollow tube and I bent it up gripping it with a pipe wrench trying to break the nuts free). I'd think that'd be a $5 part in a wrecking yard or in a parts car. Got any wrecking yards nearby? And congratulations on the belts and rollers and stuff!
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. Last edited by mikepellegrini; 03-18-2009 at 06:37 AM.. |
Feelin' Solexy
Get in touch with George at 944ecology.com, he will hook you up with a good used one pronto.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
meister member
Do you want the whole thing or just the end part?
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
To prevent this from happening, the first step is to loosen the turnbuckle retaining bolts before loosening the locknuts on the presure rod. Once the proper tension is achieved by turning the pressure rod, tighten the locknuts and then tighten the retaining bolts as the last step.
Peace to the Brave +++ 1983, 1984, 1987 944 N/As |
meister member
I do have an extra one which is all cleaned up. I would have to ship it out today though as I am tied up the rest of the week. I will PM you with my cell #.
Speedy
cheers!
thanks everybody.
PM sent
meister member
part sent today at 2:00.
Speedy
I had a similar break on my power steering turnbuckle, right through the threads near the looped end.
Just thinking out loud
What's power steering?
I lost the whole rod, the only thing left was the eyelet closest to the passengers side. I heard it as it went out the back. I was on a road trip when it relieved itself of its duties. I was glad I had a 1 inch smaller belt on it, even if I didn't have the low side on the compressor or hadn't swapped to 134, it came in handy. The short term fix included cat 5 ethernet cable, I left it that way for a good month or so.
83 944 91 FJ80 84 Ram Charger (now gone) |
I had mine tied up with speaker cable for 4 months. I have it mounted now, but with the wrong size screws and whatnots. It's not connected with a belt though.
Funny. I never thought that I could shear off a 13mm stud like that, but there it went! Right in half! As far as I know, the alternator turnbuckle is fine
