Can't put the car in gear!, or "Is this Linkage Correct?"
I recently just got done putting in a brand new transaxle in my 1984 944. So, while I was upgrading the trans, I decided to upgrade the linkage with a Weltmeister short throw shifter.
After following the worlds worst directions, I figured out how to put the assembly on the car. But, now, the car WILL NOT shift into gear #2,4, or reverse. I must have something backwards. ![]() ![]() ![]() Or, I may have the support bar- the filthy copper bracket that attaches to the other side of the trans- in the wrong spot. But I only found one hole over there... Ideas? C/Ns:New short throw, can't access gear R,2,4. Last edited by thewerxracing; 09-09-2009 at 06:11 PM.. |
It looks like the linkage is hitting the cross member at the top... preventing it from moving towards the rear of the car, thus no 2nd, 4th, or Rev.
Try moving the linkage down to the second hole, (will shorten the throw), and move the linkage away from the cross member. Also, turn the plate around, so the bolt on the bottom mates to the flat section of the shift rod on the transaxle. (This may be slipping in its current configuration) Top drawing: current positions Bottom drawing: suggested configuration ![]() good luck, JM
JM, the shifter rows through the gears just fine. No linkages hit or bind.
Although it looks like that flat spot on the rod is perfect for accepting a set screw, the other side actually has a recess in it, like a non threaded screw hole, for one. So I went with that side because that's the side the factory set screw is on. |
Main > 924/944/968
Minimize Text Default Enlarge Text Short Shift Kit (Weltmeister) - 924, 944 Save to list Comment (0) Subscribe Procedure: 1. Raise care on lift or place on jack stands. Make sure car is safely and securely supported, and you have plenty of room to see around the transaxle. 2. Locate the shifter assembly on the top left (driver's side) of the transaxle, just behind the left half shaft (diagram 3) 3. Remove the stock shifter linkage as follows: Remove the 13mm bolt which connects the shifter shaft, which runs along the top of the transmission, to the shift linkage assembly. It will be hidden under a rubber boot. Next, Remove the 10mm bolt which connects the linkage to the selector shaft (#9, diagram 1) which runs through the ball joint of the linkage assembly that is held with a 13mm nut (arrow, diagram 2). Remove linkage. Follow the rod, which you unbolted, down to where it is bolted to the transaxle. Push up on this rod so that it bends at the transmission and forms a 30 degree angle (diagram 2). 4. Your Weltmeister Quick Shifter is now ready to be installed and adjusted to suit your driving style. Use the original hardware with Red Loctite (R) (supplied with kit). For a very quick side-to-side action install the ball joint bolt in the top slot of the steel plate. By using the lower slot you will slow the side-to-side action. The fore and aft motion is also adjustable. Position the 8mm Allen bolt which secures the heim joint in the lower hole for the shortest fore and aft motion of the shift lever (about a 45% reduction). By using the upper hole you will have a 25% reduction from stock. When tightening the heim joint, make sure it is parallel with the aluminum arm. This provides the full travel necessary for proper shifting. Failure to position the heim joint correctly will result in shifting problems. NOTE: We recommend starting with the longer shifting pattern. The shorter position is radically shorter, and not always appropriate for street use. 5. Adjust the shift linkage: 1. Adjust Shift lever to an inclination of 85 degrees by moving the shift lever console (diagram 4). Shift lever should be in neutral for this adjustments. 2. Shift lever in neutral. In this position a spring will hold the lateral selector shaft in the center shift plane (3rd and 4th gear). When shift is adjusted correctly, the shift lever will not have lateral inclination. Adjustments are made on the intermediate shift lever for joint rod. 6. Double check and make sure all bolts are properly torqued and Loctited. After 10,000 miles of use, the heim joint in the quick shifter linkage will need to be lubricated. Remove the 6mm Allen bolt securing it to the aluminum plate and pack some grease into the hole on the lower side. 7. Test drive the car. Some changes in the adjustment of side-to-side and throw distance may be needed to decide what setup best suits your needs. Applications: All 924S, 944, 944S, 944S2, 944 Turbo Tools: Floor jack and jack stands, Basic hand tools - wrenches/ratchet/sockets/etc... y. |
DP,
I stared at those directions-- the hard copy that came in the kit-- for about twenty minutes. I followed them and still had this issue. But now, after spending some time watching my girlfriend shift through the gears, and gaining a better understanding of how it works, I made a few adjustments. A reset in fourth gear, making sure everything is parallel, and a quick tighten up made the problem dissappear. |
short shift
the angle is very important to the shift movement in rear as well as the shifter degree pm if needed
