How much voltage does a fuel pump need to run on?
Mine is getting about 6V, But does anyone know the bare minimum volts would be?
Old 11-11-2009, 12:40 PM
I would think that it is a 12v pump as most systems on this car... Now how many amps it needs... That is the question...
Its on a 15amp fuse so... I would guess somewhere in that range...
Old 11-11-2009, 01:05 PM
I don't see where you are coming from.
Old 11-11-2009, 01:52 PM
Professional Bull5hiter
Outback Porsche's Avatar
For me The queston is; where am I loosing the 6 volts.
Corroded wire connections. Clean, clean, clean....(and/or replace)
Jeff
83 944 Guards Red
23 718 GT Silver
Old 11-11-2009, 01:56 PM
Jeff, I was thinking the same thing.
Old 11-11-2009, 02:09 PM
This car.... Like every other vehicle made in the last 50yrs. Has a 12volt system. Therefor things on them like to run on 12volts...
Old 11-11-2009, 02:43 PM
bearone2's Avatar
about 5a to run the pump.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 11-11-2009, 07:11 PM
I'm not quite sure, but where do the amps come into play?
Old 11-11-2009, 08:51 PM
choinga's Avatar
Any time you have voltage you have an associated amperage (and resistance and wattage)
Old 11-11-2009, 10:43 PM
bearone2's Avatar
a/c, lights, big amp/stereo, fuel pump all provide a draw on the electrical system and can be seen on a decent led/dogital volt meter.
get your vehicle up to operating temp and connect/watch a voltmeter connected to the battery while someone turns on the lights, then a/c and watch how the voltage drops because of the incresed draw of amps from the electrical system.
the alternator is rated in amps, not volts.
Old 11-12-2009, 02:26 AM
Redline Racer
HondaDustR's Avatar
It might run on 6v, but it's not going to develop full pressure. It's basicly a DC motor, which runs faster the more voltage it gets, and that's because more voltage for a given resistance means more current, which means more power used by the motor, stronger magnetic pull in the motor, more mechanical work done... There's extra resistance somewhere where it shouldn't be (DME relay, fuel pump connections, corroded grounds, fuel pump motor failing, internally corroded wires, etc.), or there's extra drain where there shouldn't be, like a voltage leakage to ground, but not enough to go over 15 amps. I'll bet scenario #1.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-12-2009, 09:20 AM
Yes, any damaged wiring can cause the problems youre seeing.
Smokey - 1986 951 2.7 liter MID sleeve big bore with Vitesse and CEP parts, Link G4 Extreme, lots more.
"The first 50% of the project takes 90% of the time... The rest of the project takes the other 90% of the time."
Old 11-14-2009, 09:11 PM
How would I test for that?
She has a brand new fuel pump, and DME relay.
Old 11-22-2009, 08:15 PM
