Taking out a S2 instrument cluster
Hey guys
I need some quick tips to take out the cluster. and whether or not the steering wheel needs to come off. Many thanks
Garage Helper
Yep you need to remove the steering wheel - then there are 9 screws holding the gauge cluster cover - and four more for the gauge cluster it self, +++.
See Clark's Garage Shop Manual for an excellent write up procedure - Clark's Garage Home Page Shop Manual - Gauges - Electric 07
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word Last edited by Cocacolakidd; 09-15-2010 at 03:29 PM.. |
Excellent link !!
Many thanks, speedo gear replacement time!
IIRC, You have an Air Bag. Disconnect the Battery for at least 30 min. to disable it and be very careful after that. That bag carries one heck of a wallop to the face.
Ref: Clark's garage.com If this is an air bag equipped car, you'll have to perform the air bag reset procedure to reset the air bag warning light. On newer 944s (S2) and on the 968 this must be done at the dealer with a Bosch-Hammer diagnostics tool. Cheers, Larry Last edited by Grandad#3; 09-15-2010 at 04:55 PM.. Reason: add |
He pulled the cluster and changed the stock instrument lights to LED.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
