okay i got a 85 944 non turbo and this guys told me he'll sell me his 86 944 turbo the back end is messed so i was thinking of swapping his turbo motor into mine my question is can it be done? what do i all need to swap it out? and can i bolt the turbo motor to my trans? his clutch is burnt out so was thinking of just using my stock one or if anything save up for a bad ass clutch any help would be appreciated thanks
^^ Read carefully please.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Toofah King Bad
Buy the 86 and rebuild the ass end as a Carrera GT.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Swapping the magor parts would be pretty standard, the wiring and engine controls would be a HUGE issue. Often guys ask about this, the best responce is always sell the na and buy a turbo. The swap isn't easy enough to be practical.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
The point is if the N/A is stock, it needs a lot of work to come up to turbo standard. If on the other hand the car is fully setup (suspension and brake wise), then it is only a HUGE endeavor...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
Re
Not worth you time and effort. Sell the NA and buy a Turbo. Much less of a pain.
If you got lots of time, it can be done. Yea, it may be kind of silly, but, it's your project right?
I'm nearly complete with my conversion to turbo and it has taken a while but it has been VERY rewarding seeing as how I've rebuilt it from the ground up.
944S --> 944 turbo S - 2.5L Dry Sleeves, K26/8 Turbo, LR Height Adjustable Motor Mounts (-1/2 in.), LR 3 Piece Xmember, LR 3 Piece Xover Pipe, LR Oil Pan Baffle Kit, 930 Clutch, Lightened Flywheel, Custom RX-7 Oil Cooler, Apexi EBC, Tial 38mm Wastegate, Full 3" SFR Exhaust, etc... |
Under the car
My thought is its probably much easier than doing any of the V-8 swaps as seen below but many people with motivation still complete those. Almost all of the parts will bolt directly over since he has both vehicles. Is it an early or a late 85? I am not sure why someone asked about having the suspension all set up either because all of that can be directly swapped over as well. The wiring harnesses should be able to be swapped out as well. The only legitimate concern I can ever remember hearing about is the intercooler location but in reality I think that's a pretty simple problem to solve.
Id say go for it since you have both vehicles.
hi
i do the same with my 86 NA-convert to 88 turbo. so i incorage you to do all the work on the turboengine before put it in your car because every work on the turbo is time consuming and you must put a lot of thing out... Start with all the gasket and seals,the clutch is very important to be perfect for many years of pleasure!!!Take a look with a gauge for the turbo axial and radial play,rebuild if neccesary. The electric diagram is very similar so the only complication is the auxiliar water pump. The rest(arms,brakes,stabilizer) is time to rebuild all the busching-i put polybronze and polyurethane and is easy and fun to do. You will spent time for put the intercooler and eventualy changes panels,front bumpers,wings. For the transmission i encorage you to have a "weekend trip" tempo with NA unit because with a hard drive you will destroy the ring/pinion assemby Try to find a good 944 s2,turbo or maybe 968 tranny in future. I do this only because find a good turbo selvage and have the time to do it but when you started you will see many little trouble,rebulding,money spending.... Good luck,you will need it like me...
porsche 924 carrera gt 90% ready porsche 944 NA 86' half 951 951 full project for 944 chrysler 300M 6 x 924 and 944 canibalized or death |
alright thanks alot every1!! actually i got a friend who specializes in sr20's i know may sound crazy but he can drop one in i haven't seen a Porsche with a Nissan sr20 turbo lol but still thinking maybe just leave stock
Rocket Surgeon
buy the whole car and swap everything. it's the only way to even think about doing it.
'89 951S, Velvet Red Plymouth Superbird, Corporation Blue Plymouth Superbird, Blue Fire Metallic |
as long as the whole 951 is there (even if body is messed, mechanically sound) go for it, its not as hard as its made out to be; everything will swap over. someone mentioned the only problem being intercooler plumbing; you will have to remove the front badge panel if you have the early car which requires drilling spotwelds, only takes like an hour though.
..or you could swap your NA's backend to the turbo car..lol |
Location: In a dumpster behind Albertson's in Los Angeles County
It's a project car, just do it!!!!!!
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Banned
swap harness too. shouldnt be a problem...?
