My 944 will not start - Please Help!
Good evening friends,
My 1987 944 NA had a failing fuel pump and a leaking fuel injector seal. I was aware of the pumps condition for a short while and it was a concern but as soon as I noticed the fuel injector leak I shut it off and left it parked in front of the house until I could repair it. Unfortunately work has been hectic and I didn't get around to the repair until today (I parked her in the driveway about 6 months ago).
I replaced the fuel pump with a new one and went ahead and changed out the fuel filter while I was down there. I also did a complete fuel injector clean and reseal. I put the fuse back in, inserted my DME relay, hooked up the battery and nothing! The fuel pump didn't power on. I rechecked the electrical connections, fuse and relay and tried again. Nothing. I then disconnected the battery, took off the rear wheel and went back to check the pump. Everything was in order and checking the terminals with my voltage multimeter I confirmed no power. I disconnected the cable and hooked up a couple wires to a battery to test the pump just in case and it worked fine.
Obviously I put everything back together, checked the relay and fuse yet again and gave it another go but still nothing. The pump isn't getting power and thus the engine has no gas to fire! So what's wrong? Any ideas?
The car started and ran just six months ago. Nothings happened to it and all I did was the repair mentioned above. It does have an alarm system bypass which I considered being the culprit but it hasn't been messed with since that was performed years ago. I'm out of ideas and could really, really use your help.
Thank you kindly.
Old 08-28-2011, 04:39 PM
Just to bump this up.. for general knowledge..
The fuel pump doesn't turn on till the DME senses the engine cranking via the speed sensor.. this is indicated by a small wiggle of the tach needle durring cranking.. IIRC teh DME needs to see 200 RPM before activating the fuel pump.
Old 10-05-2011, 10:14 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Sad situation
I get a job, get busy with life and what happens......
You guys fall asleep on a newbie no start question.....
John: make a DME relay jumper and let me know if that works.
Do a search on how to make the stupid jumper.
No power to your FP means your relay is dead or not getting signal, power or ground.
Buy a new one from our sponsor... everyone needs a spare.
This is NOT rocket science guys......
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 10-07-2011, 07:24 PM
