AFM #725
Gawernator's Avatar
Weird A/C Gremlin?
So, the A/C in my '86 was converted to R-134a by a PO. It works very well actually, but the fan works on settings 2-4 only with the A/C on. At setting one, there is no movement, just like on setting 0 or "Off". This isn't normal right? With the heater turned on, setting "1" does work however.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 05-31-2012, 08:29 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
should work at all 4 settings with either the heater or a/c on
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 05-31-2012, 08:32 PM
AFM #725
Gawernator's Avatar
So what could it be? Everything about the HVAC works except cooling at setting "1".
Old 05-31-2012, 09:34 PM
89-944NA's Avatar
setting 1 on the a/c is very low, tape a small piece of string to the vent, turn on the a/c, and set it to 1 on the fan switch...should see light movement on the string (just a bit more than it moves with the fan off)
Semper Fi
Old 05-31-2012, 10:40 PM
AFM #725
Gawernator's Avatar
Thanks, I will try that. I have sat there with my hand just feeling for anything and I swear there was no movement, but the string test will be helpful, for sure.
Old 05-31-2012, 10:52 PM
89-944NA's Avatar
it has to be some pretty light string, like kite string, or heavy thread. Good Luck
Semper Fi
Old 05-31-2012, 11:39 PM
Just thinking out loud
mattdavis11's Avatar
It's probably the switch, but might be the resistor. Take them apart to clean them, or buy new ones.
91 FJ80
84 Ram Charger (now gone)
Old 06-02-2012, 10:09 AM
a 1 hour soak in white vinegar works well for dirty resistors
86 951 blk
Old 06-02-2012, 10:19 AM
968 GUY's Avatar
Resistor more than likely.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 06-02-2012, 10:24 AM
