hard start when temp is below 40 F
Car starts fine excepts when it gets real cold. Its been doing this the last few yrs and since i havent been driving it in cold weather i never fixed it. Now i want it fixed!. Car is 86 turbo.....i replaced fuel filter, and fuel pump check valve.. but i haven't ever replaced plugs in 15K miles since i've owned it over 5 yrs. Any other suggestions
AFM #725
Possibly the DME temp sensor. Like a $20 part, get the Bosch. Easy to install and remove. It senses when the engine is cold and enriches the fuel mixture until it warms up.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Location: In a dumpster behind Albertson's in Los Angeles County
Move to a warmer climate? Sorry, I just couldn't keep from saying that
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
AFM #725
36 down here too..but the car sleeps in the garage, I've never had a problem starting it on cold days though
AFM #725
It started up right away after sitting outside that night, yikes, sorry car. Never has failed me, so far.
Andrew Gawers' Dad
What oil are ya running, 20w50?
AFM #725
I'll assume that was towards OP, however I run 20w50 and have no start issues, coldest I've started is 36 degrees now. According to the owner's manual, porsche says 20w50 can be used down to around 10-15 degrees F
My car has been having a hard time starting lately now that's cold and almost didn't think it was going to start while cranking it today. What are the part numbers for the DME temp sensor and fuel check valve for an 84? I have tried to look them up before but don't want to order the wrong parts.
1984 944 NA 5spd |
AFM #725
This check valve? 944-608-951-01-M14 Pelican Parts - Product Information: 944-608-951-01-M14
As for the temp sensor, referencing this thread: http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/184320-temp-sensor-dme.html Would appear that this: http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=944-606-125-00-M14&catalog_description=DME%20Temperature%20Sensor%20% 2820C%202%20Pin%2C%20Blue%29%2C%20924S%2F944%2F968 %20All%20%2802%2F85-89%29%2C%20Each%20 Is indeed the correct sensor. Idk why PP has it listed as 85/2+
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com Last edited by Gawernator; 12-22-2012 at 02:28 AM.. |
i had same problem ...i fixed mine by replacing the rubber hoses the go to the idle control valve .....they were dry rotted and cracked
1985.5 944 N/A. |
When it's cold in the morning I'm hard to start up, but I'm old as dirt. It'll be 27* in the morning.
Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
thanks i'm gonna try new temp senser
It's hard to start me up in the morning whether it's cold or not! And I'm not old...yet.
Guy '87 944 (first porsche/project car) |
AFM #725
I must still be a new engine
