No substitute!
I noticed that the OPRV sleeve is not in the block. Did you remove it or did it fall out with the valve assembly? Mine just fell out when i removed the valve.
I reassembled mine after a oil/coolant issue and have not been able to get oil pressure back. Slow getting back to redoing the job as my sleeve is loose in the block and I have to open it back up and seal it in place with the Loctite. I tried just tapping it back in place; didn't work so well. There is a procedure in the WSM on it. I am gearing up to go back in and get it working. Really enjoying watching your progress - you're inspiring me to get moving!
1984 944 NA Man Grey (Sold) 1985 944 NA Man Guards Red 1985.5 944 NA Auto Kalahari Beige |
Converted 944 Guy
Which style OPRV do you have? EDIT- OK- so the Tech Bulletin points out that the 3 piece OPRV requires a sleeve in the OPRV passage. Yaaay! Yet another item discovered after the fact. So the sleeve must be tapped in using the P9215 alignment tool. I will fish around for the sleeve inside the passage, and ensure it is secured properly. Last edited by tstark; 12-05-2013 at 03:12 PM.. Reason: EDIT- |
Converted 944 Guy
Proprietoristicly Refined
I attach it to the cooler housing held on by the RTV.
If you do not have the WSM go to your Haynes 944 book on page 91 section 29. It explains the installation of the oil cooler housing. J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) Last edited by John_AZ; 12-05-2013 at 11:52 AM.. Reason: See Haynes |
Converted 944 Guy
Found the OPRV sleeve in the OPRV canal on the engine block. It is sticking out some, but pictures look like its seated in the back of the canal. It is stuck in its position solid. Is this the correct position or does it need to go in deeper? See pics below.
No substitute!
Sorry, I was looking at the pics wrong. Glad to see your sleeve is intact and one less thing to worry about.
Converted 944 Guy
The alignment tool is grooved specifically to drive the sleeve into place. So driving it in will not be a problem. Getting the sleeve out without damaging it may be the problem. The pictures on Clark's looks pretty similar to mine, so I'm not gonna mess with it. |
No substitute!
Might be careful there... I tried using the alignment tool I got from Pelican and tapped it in. It sort of wedged in there and I had to work it out of the sleeve. No damage, but scary. Almost had to go on a part search! It is supposed to stick out as yours is configured. I would leave it alone. My sleeve came loose again when I went searching for oil pressure after the OC reassembly since I did not use Loctite.
Converted 944 Guy
Converted 944 Guy
Oil cooler resealed and torqued in place. Was able to pull this off without removing the headers. So a minor victory there. Hopefully it's all in place correctly. When I pulled the cooler off it had no plastic washer or metal washer on the boss. When I put it back together the cooler would not go into the housing. I removed the plastic washer and the cooler fit fine. Measured the distance from the boss and housing, it was within spec without the metal washer.
So I basically replaced it, the way I found it. Getting the early OPRV in was a challenge, as the spring was very strong. But managed to get it in and torqued. Hopefully it's seated correctly. Used the early alignment tool, so we'll see once I'm finished and able to fire her up. |
Converted 944 Guy
What's the torque ratings for the upper and lower balance shaft over bolts. Haynes manual is confusing. I'm referring to the covers not the shaft housing. The covers that are removed to replace front seals.
Thanks! |
Converted 944 Guy
Nevermind I found it!
Converted 944 Guy
Two basic questions. First what's best tool to install keys in balance and crank shafts? Also, oil pressure sender wire, can't remember if it mounts on water pump bolt or timing cover? Does wire run behind timing cover or over it?
Wire goes behind timing cover, right up against the head. there's a little ledge in the castings to support it with a tab I think on each side that accepts a zip tie to hold the pressure sender wire in place.
"porsche it's an institution" |
Converted 944 Guy
Frankly my dear....
Hi there, just went out and had a look. The bracket is fitted on that WP bolt, but should be facing inwards. So, just remove, rotate and refix. Then the wire can pass behind the cover (over the WP).
Hope that helps.
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
Converted 944 Guy
Converted 944 Guy
Getting ready to put the balance shaft sprockets back on. Just checking on the proper installation. The top sprocket has the O in the large circle and the bottom has the O in the rectangle, correct? See pic of the top BS sprocket.
Frankly my dear....
Yep, just had a look, you are right...and nearly there now!!!
Regards.
Converted 944 Guy
I didn't see any mention of it in the procedures, but I'm assuming I need to use some lubrication on the inside of the BS sprokets in order to tap them into place? The woodruff keys make for a tight fit on the sprokets. I tried sliding them on dry and like the oil sleeve they just won't slide on without it. So I'm going to lube the shaft and inside of the sprokets.
Unfortunately, I just realized my lower balance shaft bolt is in bad shape, so I'll need to order a replacement. |
