Alternator question
In the process of having my waterpump changed the mechanic noticed the bearings in the alternator are not that healthy either.
Is it possible to buy new bearings for the alternator or is a new or refurbed alternator the way to go? Also I've been looking at refurbed alternators and can see there are two different ratings 90 and 115 amps. My car is an 84, can I go for either option? Thanks
1984 944, 2.5L, manual transmission, UK right hand drive. http://944foot2thefloor.blogspot.com/ |
Proprietoristicly Refined
You can get new bearings. Your mechanic should have not problem in matching an old to new.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/767617-what-correct-alternator-bearing.html The normal part replaced is the regulator. The part that is usually the most forgotton is the "slip ring". The old regulator will wear a groove and the new regulator brushes will not have a flat surface to contact with. ![]() Add all the parts together and just get a "remanufactured" --most parts replaced rather than a "rebuilt" --cleaned, painted, tested---parts replaced are minimal. 90 or 115amp? I would go with the 115 amp if the same price in the UK. The wires on your '84 have built a resistance. You should actually change the battery "+ -" wires and the battery lead connectors. Many go with the "Ice Shark battery cables or similiar. Top of the line. IceShark Cable Kits... - Rennlist Discussion Forums GL J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
The 115 amp alternator will not fit (physically) in an 84 944.
Good luck, George Beuselinck |
Is it possible to "upgrade" the exsisting early 90 amp case to 115A? Thanks again. John
Thanks just confirmed with a parts shop in the UK that I need the 90 amp version too.
Back from Beyond
Yup - 90 amp. The two alts are different, as GB stated. I also believe the pulley grooves are different... However, a late alt bracket should bolt up to an early block.
Bearings are a straightforward change over, as is the reg. if your slip rings are good and resistance checks out, bearings and reg will keep your alt going forever. Ring to ring: 2.6 spec Ring to shaft: infinite ohms |
Back from Beyond
A other thought... Beware 6201 rear bearing. I seem to recall it not being the right depth for my 84.
I am going to get this one when I put a few 18" bass woofers in the hatch...
Sounds expen$$$ive!
I found an auto electric shop that was happy to do a rebuild. It was less than the cost of a rebuilt off of ebay. Since it is a Bosch alternator it is not as exotic as some of the other 944 sub assemblies. So far so good...
The late alternator should fit the early cars.... with a bit of file work.
I have an early ac delete bracket (they are all early) with my late alternator, and it fits fine.... a tad loose between the ears. 944 126 123 06 late bracket with ac 944 126 017 04 early bracket with ac I replaced the bearings and voltage regular in my alternator. Unfortunately you can't do anything about the flip rings. They can't be removed... or I should say, I did not brutalize it and screw myself. The bearings I pulled out are 6303 and 6201
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
Wait a second..... I recall Massive has no AC! if I'm correct, a late alternator will fit no problem.
The mechanic should suggest a full FOES replacement and maybe new timing belt kit to go along with the WP & alternator replacement. J_AZ
Early 944s have 5 rib pulley and the late ones have 6 rib pulleys on the alternator IIRC.
Dimi P. flyinghorsemotorsport@gmail.com 1986 Porsche 944 (3.0L 16V Conversion) - on track duty! 1989 Porsche 944 $2 - for show and fun!
Dimi Paralanov Flying Horse Motorsport flyinghorsemotorsport@gmail.com |
