I own a 1986 944 and the car turns over but will not start i am not getting any spark and I would like some help in what part should I check to get my car started. I have replaced the spark plugs, wires, dist. cap, rotor, timing sensors, dme relay, fuel filter, fuel pump, coil, fuel pressure regulator. I am running out of ideas in which I am suppose to do to get the car started. Any help would be greatly appreciated.
Are you getting spark from the coil? If not, check all the power and grounding connections to the coil. Sounds like you've replaced everything except the DME itself. If you have good power to the coil, next place to look is your computer.
Check you grounds, check your fuses. start at the plugs and worlk your way back.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
I had similar problem with my 1988. After replacing most of the same parts you did the problem actually turned out to be a damaged flywheel. Has a ring of teeth on it. Mine had many missing. Apparently the most important fuel system sensors get their basic info from those flywheel teeth. Changed the flywheel and my car ran like new. No trouble turning over without starting. Have your mechanic check it out if nothing else shows up. Good luck mine was in the shop 5 weeks and $2000 to find it!
Terry
Mark '86 944NA |
