your favorite oil filter wrench/socket
great - I broke my cheap oil filter wrench/socket (four spot welds holding it together). gotta upgrade. what's your favorite?
I saw two on Pelican:
Pelican Parts.com - Oil Filter Removal Socket, 74mm 3/8" drive, For M102, M103, M104, M111, M112, M113, M119, M120, M137, M155, M272, M275, M285, OM611, OM612, OM613, OM628, OM646, OM647, OM648 Engines
Pelican Parts.com - Oil Filter Socket - 74mm
How do the "jam bolts" work on that one up there?
Paragon has one, maybe Arnworx. is the Hazet worth it?
UPDATE: might as well add : from the shop manual, vol.1:
Mann & Hummel designation LS 7
special tool 9204
oil filter torque 20 Nm ( 14 ft. lb)
87 944 NA
Last edited by Bukowski; 01-30-2016 at 11:47 AM.. Reason: added info from shop manual because why not
Old 01-11-2016, 03:43 PM
ideola's Avatar
I prefer the universal variety:
I mean, c'mon, you're not going to use the filter again once you remove it. The channel locks are quick and easy, and can get into just about every angle, on the hoist, from above, lying on your back with the car on stands, etc. One of the best tools my dad ever bought for me when I was doing light mechanics working my way through college.
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 01-11-2016, 03:52 PM
That's what I use too.. LOL It just takes a little twist to get it started...
Old 01-11-2016, 05:29 PM
ideola's Avatar
Yeah, that's what she said
(sorry, that was too easy)
Old 01-11-2016, 06:05 PM
My two bare hands on a cleaned filter....if that dosen't work, I use the big-azz channel locks like shown above (just about the same size too).
Old 01-12-2016, 03:45 AM
The Harbor Freight oil filter pliers is good too. I have an end cap wrench but it only fits a subset of the 944 filters and does not update itself when filters change.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 01-12-2016, 04:24 AM
Some backstory : using a Mahle filter. Had to go to the 25" breaker - that's when the filter socket broke at the four welds between the detent and sleeve (?).
I plan to heat the filter with driving before removing it again.
Old 01-12-2016, 05:17 AM
Any oil filter removal tool that breaks indicates one (or more) of the following: - a defective tool, a careless owner/PO/shop over-torqued the filter, and/or the filter hasn't been removed in ages and has glazed itself stuck, plus any of the above when combined with dry contact surfaces upon installation.
Old 01-12-2016, 06:23 AM
Originally Posted by OK-944 View Post
....and/or the filter hasn't been removed in ages ....
That ^^^ is true
Old 01-12-2016, 06:45 AM
ideola's Avatar
Spray the filter mating surface with PBBlaster or some other similar penetrating oil before running heat cycles. The big channel locks will get that mofo off of there. Don't be afraid to mangle it during the process!
Old 01-12-2016, 06:51 AM
Just thinking out loud
mattdavis11's Avatar
If I can't turn it with my hand, I use anything that can help. I have a band style wrench with a swivel handle, old timing belts, aforementioned channel locks, screw drivers, and a 15 year old.
The 15 year old got the last one off on his mothers' MDX.
My favorite is the 15 year old.
91 FJ80
84 Ram Charger (now gone)
Old 01-12-2016, 07:11 AM
Proprietoristicly Refined
John_AZ's Avatar
Jeeeeeeez!
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 01-12-2016, 07:29 AM
I've done that before also, when out of ideas.....shove a screwdriver through both sides and turn it like a handle.
Old 01-12-2016, 07:50 AM
LOL. If I put it on, it'll come off no problem.
91 FJ80
I don't know how many times I've done that. Way too many though. If you oil the seal people...
91 FJ80
Old 01-12-2016, 07:57 AM
@mattdavis11 : I oil the seal - or might have used silicone grease as an experiment.
Old 01-12-2016, 08:10 AM
jhowell371's Avatar
Harley Davidson Dyna Glide series oil filter wrench. It has a cut out area to clear the Harley's crank sensor that is perfectly placed for hose clearance for removing my S2's filter.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 01-13-2016, 02:49 PM
Really, in all of my days I have never had a problem...
Old 01-13-2016, 04:56 PM
campbelljj's Avatar
Assenmacher 2175 74.5mm OIl Filter Socket
Works great
Old 01-14-2016, 07:06 AM
Broke
Westy's Avatar
I wish I had photos of some of the oil filters I've removed after utilizing the self adjusting oil filter wrench, the screwdriver attack, and the Channel Locks mangling! I'm pretty sure in NY or San Francisco I coulda got a nice artistic collectors price for these one of a kind statements.
Beer is proof that God loves us and wants us to be happy. B. Franklin
93 968 Cab
81 SC Targa (Princess) Now Residing in Denmark
1973 RS Z28 Vash will never own it!
Old 01-14-2016, 03:06 PM
