928 dash failure
My 1978 928 has a reocuuring dashboard failure. Sometimes when I start the engine all dashboard instruments fail including dahoard light. Is this related to the adjusting of the steering with dashboard pod? Is there a fix?
Tanks
Ad
Old 07-01-2006, 11:05 PM
If the left or right side fails individually, the problem is normally a blown/corroded fuse. Since both sides of yours are failing, the problem is either a corroded ground wire under the dash, a crack in the printed circuit card (behind the gauges), or a bad/corroded connection at the multipin connector on the printed circuit card.
Dennis
Old 07-08-2006, 08:04 PM
Hi Dennis,
Thank you for your respons. I think the ground wire is cousing the trouble. I've heard it is sort of a sliding ground because of the adjustable pod. The instruments mostly come back into live when I put the steering/pod in the upper position.
Old 07-13-2006, 10:00 PM
efhughes3's Avatar
Most problems with pod lights & gauges seem to be related to grounding. If you've not found it already, Rennlist is the place for 928 fanatics. Pelican is stronger for 911's.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-16-2006, 10:52 AM
