Garage: Yes but no roof.
HELP: Removing front brakes
I'm replacing the brake pads & discs.
I can only get 1 of the 4 countersunk bolts off to remove the discs (2 bolts per wheel - on the faceplate of the disc after you've removed the wheel).
I've tried WD40 to lubricate, but no joy.
Any ideas? Will tapping it anywhere help? Will I have to drill them out?
'84 928S (Euro) Automatic Shiefferblaumetallic
Old 12-02-2007, 03:44 AM
Network Native
Danglerb's Avatar
I've stocked up on several penetrating oils, WD40, PB Blaster, Kroil, Liquid Wrench, and a few more still to go like the GM stuff.
Here are a couple threads.
http://66.236.61.177/showthread.php?p=3490364
http://forums.pelicanparts.com/showthread.php?t=365140
Old 12-02-2007, 08:08 AM
dprantl's Avatar
An impact screwdriver will get those out every time (the kind you hit with a hammer). Here's an example of one:
http://www.sears.com/shc/s/p_10153_12605_00947641000P
Old 12-02-2007, 09:45 AM
Fabio421's Avatar
Yep, what they said. Impact screwdriver. If you don't want to buy one. Take a screwdriver and hold it in a pair of chanel lock pliers. Hold some steady pressure in the counter clockwise direction and start tapping it with a hammer. The larger the hammer the better. You'll get it out.
1984 928's w/ 5 speed Smoked Quartz Metalic
1982 928's Turbo w/ 5 Speed Platinum Metalic
1978 Euro Widebody w/ 5 speed Guards Red
Old 12-02-2007, 10:14 AM
Herr-Kuhn's Avatar
You can also try some heat...that may help. The impact screwdriver is a must to really get them off though.
Kuhn Performance Technologies, LLC
Big Gun: 1988 928S4 Twin Turbo, 5-SPD/LSD 572 RWHP, 579 RW ft-lbs, 12 psig manifold pressure. Stock Internals, 93 octane.
Little Gun: 1981 928 Competition Package Twin Turbo, 375 RWHP, 415 RW ft-lbs, 10psig manifold pressure. Nikasil Block, JE2618 Pistons, 93 octane.
Old 12-02-2007, 11:16 AM
Thanks all,
Heat applied with a heat gun, gave it a whack, and got them all off.
appreciate the help. Will need an impact screwdriver for sure though now.
Pauwl
Old 12-02-2007, 11:35 AM
Fabio421's Avatar
Use some never sieze on them before you reinstallation. It will keep you from having this issue ever again. The bottom of the head needs to be lightly coated as well as the threads.
Old 12-02-2007, 12:53 PM
Network Native
Danglerb's Avatar
Impact screwdriver is cheap, everybody should have one, and even better remember that they have it.
Old 12-02-2007, 06:03 PM
