Petie3rd
Mrmerlin's Avatar
just a note to turn the cams use the BIG nut portion not the cap screw
IIRC the big nut is a 30mm, you can inadvertently loosen the cap screw and then it will fall out
Old 10-17-2009, 06:03 AM
inventor
porken's Avatar
It could be the pics, but it looks like the cam gears are worn out, shiny from the coating having been worn off. The oil pump gear looks new.
It also looks as if the belt is HTD/round tooth (HTD is '83-up). The gears appear to still be square type, however.
POWERED BY PORKEN
1986 928S3 AT grandprixweiß weinrot #1195
1988 928S4 MT polarsilberm sw/grau #1023
liftbars.com porken.com S300s.com
Old 10-17-2009, 08:03 AM
