Coolant gauge question (is it working?)
I am terrible when it comes to electrical troubleshooting.
My coolant gauge is not registering. I have taken the plug off at the engine water bridge and ground the blue wire and the gauge will register hot. I then ground the brown and the alarm light will light on the gauge. I tested the resistance between each terminal blades of the sensor to ground. Nothing registers on the meter. When I put the plug back on the sensor the gauge will not work.
I have also replaced the sensor.
I hope I explained my problem well enough.
Thanks. Mike P
1988 Porsche 928 S4 (rescue)
Old 07-17-2012, 06:33 PM
Dean_Fuller's Avatar
Try cleaning the grounds under the steering column.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's)
1989 Auto Slate Grey Metallic / Cashmere & Black (mine)
1982 5-speed White / Black sport seats ( brothers )
Old 07-17-2012, 07:23 PM
I will clean the grounds when I get home tonight.
Where is the needle on the gauge suppose to be pegged at normal running temperature?
Thanks. Mike
Old 07-18-2012, 04:10 AM
Dean, I cleaned the grounds behind the dash. Not an easy job. I am tall. Still not working.
What else can I do?
Thanks for the help.
Old 07-18-2012, 04:37 PM
