1980 Porsche 928
Horn does not work
For some reason when I hit my horn it turns on the parking lights? I can hear the relay clicking. I'm not sure why it does that. Can anyone help? Also. My wiper blades only seem to go one speed on all settings? The combination switch is new. Any ideas? Thanks
Old 08-02-2013, 11:23 AM
harborman's Avatar
My horns did not work either, they were bad and I replaced with ones from Autozone. They are located below the right head light. You need to remove the wheel liner to get to them. But before doing this, clean all your CE panel fuses, relays, connections and grounds.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 08-02-2013, 12:11 PM
What's Facebook?
turborat's Avatar
Alarm and park lamps tied through alarm with malfunction. Wipers could motor or relay. What speed?
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 08-02-2013, 12:29 PM
harborman's Avatar
Here is the post on horns.
http://forums.pelicanparts.com/porsche-928-technical-forum/537409-horn-location.html
1986 928S
32 valve engine
Old 08-02-2013, 12:33 PM
1980 Porsche 928
I have cleaned the whole Circuit board before and all new fuses and what not. They only go the slow speed.
Old 08-02-2013, 01:18 PM
What's Facebook?
turborat's Avatar
I don't have schematics, but wiper speeds are typically in the motor. There should be 4 wires from the motor to provide two speeds and park. Intermittent is through a time delay relay circuit. Suspect motor or motor wiring.
Turborat
2001 330Ci
Old 08-02-2013, 06:39 PM
curtisr
curtisr's Avatar
At the risk of appearing to be a complete jerk, this might be a good idea in principium as it is not always obvious where exactly the horn is coming from. And if you add the benefit to hearing impaired drivers... I think might pursue this as a 'feature' and ask for a discount from my insurance broker.
Old 08-02-2013, 06:45 PM
Kool
AirtekHVAC's Avatar
Look at my it's alive thread...new horns at harbor freight now on sale for 9$....
I know this really does not help the op...but the cheap horns actually sound pretty good.
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 08-02-2013, 07:29 PM
1980 Porsche 928
I'll check into the motor.
Old 08-02-2013, 09:32 PM
19psi's Avatar
But have you ever heard the original twin trumpets?
George in Indiana
928 Weissach #153
Cayenne S
Old 08-03-2013, 08:25 AM
Kool
AirtekHVAC's Avatar
I'm sure they sound more better....maybe I'll stumble across some one day.....
Ron
Old 08-03-2013, 05:00 PM
stepson's Avatar
Just checking, but are you turning your wipers completely on? Or just intermittantly? Intermittant speed is controlled by the rheostat under the pod (which could be why you just have one speed) Flip the lever the opposite direction (up vs down or down vs up) to check.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 08-03-2013, 11:03 PM
1980 Porsche 928
I moved the dial both directions and it doesn't seem to fix the problem. Just one speed
Old 08-03-2013, 11:47 PM
